Old 06-12-2008, 10:18 AM
digr digr is online now
Default Milldrill indicator
This little project got a little more involved than I first suspected. But I learned a lot about my little mill. I wanted to mount a indicator and get rid of the hated adjusting nuts for the depth stop. I no longer have a scale on it but I think I will mount one on the bracket which is mounted on the mill to hold the indicator. The first problem was that the factory locking handle was to short so I made a new one a little longer [1/2" dia with 12 tpi] The indicator is from Harbor Freight and will stay on the mill. It will tilt forward so the stop can be used when needed. All the parts were ether milled, drilled, reamed and or sanded.
ID:	32793   Click image for larger version
ID:	32794   Click image for larger version
ID:	32795   Click image for larger version
Name:	slide with block4.JPG
ID:	32796   Click image for larger version
Old 06-12-2008, 10:22 AM
more pics
Name:	block and stop6.JPG
ID:	32798   Click image for larger version
Name:	stop and block7.JPG
ID:	32799   Click image for larger version
Name:	dial spacer8.JPG
ID:	32800   Click image for larger version
Name:	using indicator9.JPG
ID:	32801   Click image for larger version
Name:	using stop10.JPG
Old 06-12-2008, 10:34 AM
1911man's Avatar
1911man 1911man is offline
Co-founder, Harbor Freight 12 Step Program
Very nice work digr- as usual
The older I get the more I know and the more I know the less I understand.
"I'll keep my freedom, my guns and my money. They can keep the change."
Old 06-12-2008, 10:57 AM
Setup boy's Avatar
Setup boy Setup boy is offline
Press One for Trash
Thumbs up
That's cool...thanks for sharing Digr.
Thank you,
Tom(Reformed Post Whore)
This legislation will have the effect of addressing that mal-distribution of income in America."
Sen. Max Baucus Montana
Do you want it right or right now?
Ya can't polish a turd.
The Techie Geek Podcast
Old 06-12-2008, 11:14 AM
Charlie C's Avatar
More STEAM!!
Very nice work. You will use that a lot in future projects. I have something similar on my Chinese BP mill.
Isn't it amazing how a simple project turns into something more complicated?
Old 06-12-2008, 03:21 PM
I been thinking about changing the stop to a solid rod too limit the movement on the quill and get back to my DRO project in the link.
http://www.shopfloortalk.com/forums/...ad.php?t=11810
Old 06-12-2008, 03:34 PM
Team DeSade's Avatar
Team DeSade Team DeSade is offline
Send a message via AIM to Team DeSade
That's pretty slick Digr.
Terry
Old 06-12-2008, 08:52 PM
yorkiepap yorkiepap is offline
Hey digr,
Great setup & workmanship. I made mine quite simple with a piece of 1.5" X 1" alum. angle with a slot milled to be able to slide the indicator up & down to set my zero. The indicator is a 2" movement thus gives me plenty of room for adjustments. I made a circle strap with a flat-ended rod attached to the quill. Once I have the endmill set my to my zero start, I bring the indicator down to touch the rod & set depth of indicator travel for the depth of milling to be done. Just wanted to show anyone a really simple method to do some fine precision adjustments if needed. Denny
Complete weld, machine & fab shop...
A man's word is his honor... without honor, there is nothing....
Old 06-12-2008, 10:13 PM
doubleD doubleD is offline
Wow Digr,
very impressive.........as usual. Thanks for sharing and in the details.
dd
Old 06-13-2008, 12:11 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
Great job digr. There was a whole series of articles in The Home Shop Machinist magazine, some years ago entitled, "Mill/Drill Adventures". It featured a lot of the kind of stuff you're doing.
Unfortunately, most of the guys who wrote those articles, are no longer with us. You might be able to get reprints though.
I need to do somethig like that on mine because, the movement of the fine down feed handwheel is wierd. It's .083" per revolution. Makes for some mental gymnastics. I've seen where some guys in HSM have used dial or digital calipers for down feed scales. I'm thinking of going that route.
Dave
