Old 04-01-2015, 09:26 AM
gimpyrobb's Avatar
Default Fixing a car port
My buddy has decided he wants to keep his trucks under this car port. Right now he keeps "stuff" under it. Once we get it cleaned out, I'm thinking I'll take up a bunch of my scaffold and jack it up. Once its sured up, he wants to raise it a couple feet. Here are some pics for your viewing pleasure, comments and tips encouraged.
Name:	car port a.jpg
ID:	123324   Click image for larger version
Name:	car port b.jpg
ID:	123325   Click image for larger version
Name:	car port c.jpg
Old 04-01-2015, 11:46 AM
Norm W's Avatar
Norm W Norm W is offline
From the looks of the pix it may be easier to save the tin and start from the ground up with new. There wasn't any diagonal bracing from the looks of the tilted poles. The sag in the roof trusses is caused by? Rot or overload? More of a job than expected I'm sure.
Old 04-01-2015, 11:53 AM
RancherBill's Avatar
RancherBill RancherBill is offline
there has to be an answer
It's just dirty.
Norm is right take off and save the tin. This will give total access to the dirty structure. Then give it a good wash with gasoline, and then dry it with a match.
Warning Disclaimer What am I doing?
Old 04-01-2015, 12:04 PM
SmokinDodge's Avatar
Originally Posted by RancherBill View Post
It's just dirty. Norm is right take off and save the tin. This will give total access to the dirty structure. Then give it a good wash with gasoline, and then dry it with a match.
Or get a new buddy.
Sent from the ipotato
Old 04-01-2015, 12:05 PM
I agree with the other fellows--that doesn't really look heavy duty or even regular duty. Not something I'd put a car under... Or spend time on...
Old 04-01-2015, 01:06 PM
Curmudgeon
In the famous words of King Arthur: "Run away!"
and then find something else to worry about.
Old 04-01-2015, 04:32 PM
Scotts Scotts is offline
Originally Posted by SmokinDodge View Post
Or get a new buddy.
Ummmm If that is your buddy you don't need enemies.
Old 04-02-2015, 05:46 AM
funny. Never thought of cleaning that way.
Old 04-02-2015, 06:08 AM
I see allot of brush all around it as well.
Drive the Thrash-a-matic all around to clean up the place....and thru/over the carport...
Old 04-02-2015, 09:20 AM
Be real careful as she looks a little on the poorly framed side.
