Old 02-13-2012, 03:55 PM
Corm Corm is offline
Originally Posted by PixMan View Post
I wasn't thinking of using a ball end mill, but a regular 1-1/2" end mill as side cutting. It may require a long holder, but a 1-1/2" end mill with a 1-1/4" Weldon shank in a holder might be long enough.
If you don't have the stuff, throw the part into your car and come on down to MA and we'll do it up in about an hour.
Now there's something I hadn't thought of! I have a couple of 1.5" end mills. Makes perfect sense, I can't believe I didn't think of that myself. Duh! I can turn the OD in my lathe, drill and bore the center hole, then mount it on my ro-tab.
I think I like that idea better than doing the whole job in my lathe. Now I just need to convince SWMBO that I NEED this die, so I can go get the steel I need.
Corm
Old 02-13-2012, 03:59 PM
As in Pixman post,
If you want to be slow and cheap, a fly-cutter set at 1.5 dia.
Do the 'Kellering' in the lathe first, may get away with making a 3/4" radius (not a full ball) on a tool-bit ( slowest spindle rpm). finish in the mill if needed.
Using a fly cutter is another good idea I hadn't thought of. Like you said, cheap. I like that! Whether I get this done slowly or quickly, really doesn't matter. I'm mostly retired, so I don't do much of anything in a hurry anymore.
Corm
Old 02-13-2012, 06:05 PM
Just want to thank you folks for your help. It's easy to see that I am a rank rookie, so in need of a lot of help.
I read this forum nearly every day (and have learned a bunch), but don't often contribute because I am so much of a rookie. Hopefully someday I'll be in a position to return some of your help.
Corm
Old 02-13-2012, 07:55 PM
aametalmaster aametalmaster is offline
Cool
I built a ball turner/radius turner just for making pipe dies. Run your lathe in backgear that dia will eat cutters if run fast. Make yourself a tool like this for turning the radius. It isn't mine but a good concept...Bob
ID:	87399   Click image for larger version
ID:	87400   Click image for larger version
ID:	87401   Click image for larger version
Bob Wright
Metal Master Fab
Salem, Ohio Birthplace of the Silver and Deming Drill.
http://www.ceilingtrains.com
Miller MM185 with 185 SpoolMate
Old 02-14-2012, 01:44 AM
Amigo Amigo is offline
Corm:
I can envision making a series of cuts with a regular bit, each cut going a little deeper towards the middle of the groove, from each side of the groove, and then maybe finishing it with some (a lot of) filing to smooth out the steps between the cuts. I believe that process is called 'Kellering'.
Just to avoiding confusing those who do not know, "kellering" is a form of tracer machining. A tracer follows a pattern or model, while a cutting tool (lathe or mill) does the material removal of the desired product by duplicating the path of the tracer. The position relationship of the tracer and cutter is usually fixed for X & Y, Z(depth) is usually adjustable.
For your desired product, a piece of split plastic pipe could serve as your model, mounted vertically on the lathe bed. A tracer could be firmly affixed to the compound to the right of the cutting tool. If the model is near perfectly vertical, the tracer need not be on the same height plane as the cutter.
On the other hand, first making a metal slug of the desired diameter, to serve as a "gage", plunge cutting with a groover/parting tool will get you purty close. Final touches could finished with half round files & emory cloth.
Always have a round end handle on a file used with running machinery.
Old 02-14-2012, 06:36 AM
big job big job is offline
Default Low budget
Back in the 70s I got into dune buggys big time. As far as where I am I
dont think these were invented yet or I never saw one. So all I did was
to turn a piece of oak tree to the dia of my pipe inch &1/2 I then cut it
in two then bolted a steel plate on its flat back side, mounted that on a
log splitter with two VW rims that the pipe would roll on. I cant count how
many VW buggies we made, I mean they were real nice roll bars cages,
and that cheap idea never failed and all done with compound rest
Name:	radius turning.gif
Old 02-14-2012, 07:34 AM
Kbeitz Kbeitz is offline
Default Two that I made...
Two that I made...
Name:	inside radius cutter .JPG
ID:	87437   Click image for larger version
Name:	outside radius cutter .JPG
Old 02-14-2012, 05:44 PM
Cool
Heres mine. Its in ball turner mode in these pics just run it past center and it will do the radius...Bob
ID:	87454   Click image for larger version
Name:	big ball[1].jpg
Bob Wright
Metal Master Fab
Old 02-15-2012, 07:38 AM
Thanks for all your pictures folks. You've given me plenty of examples that I can use to make my own inside radius turner.
You folks are great. I was hoping for some advice regarding what I want to do. I got more than I expected, along with an offer from one of you guys to make the piece for me (wow!). This is why SFT is always my first stop whenever I log on to my computer!
Corm
