![]() I have a lot of reinforced silicone hose that I need to cut. It's reinforced with 4 plys of polyester. I'd grab a pair of scissors, but I need to make over 100 cuts. Also, these cuts need to be clean. Is there any way to do this with a bandsaw? Is there any specialty tool for this? I'm afraid that there will be too much flex with 2.5" ID. Anything? Thanks, Alex |
Check at your local Auto Parts store for a hose cutter.They work great on radiator hoses.
"Banking establishments are more dangerous than standing armies. Thomas Jefferson |
Maybe a set of Craftsman HandyCuts or similar. Sears item #00937301000 Mfr. model #37301.
Not sure how thick 4 ply polyester reinforced hose is but its what I use for most radiator hoses, heater hoses etc. If it was wire reinforced like fuel filler hose I would use an abraisive chop saw. Don |
Do you think it will have trouble with the polyester braids?
I'm guessing that you probably have a chop saw if so use it. Just be ready for smoke from the hose. If you have a miter saw I'd give that a try and see how it works. At work we have a tool that clamps the hose flat and has a blade mounted on a slide to cut the hose. It is used for rubber radiator hose, the straight stuff that's a ***** to cut any other way. Hope some of this helps.
Is this clamp you speak of called a vise grip? ![]() |
It's a flat table about 7 inches front to rear and about 8 inches wide. There is a arm that pivots at the rear to clamp the hose and it's held by hand. The blade is mount to a piece of keystock that slides in the base. The keystock has a knob mounted on the end about 3" in diameter to push the blade. If I remember correctly it was made by Gates rubber company. I havent seen it since this spring, hopefully it's still around so I can get some pics for you.
If you are doing a whole mess of them ie. production run, I would look at rigging something up. With a new blade your Ellis saw may not do to bad. Otherwise something with a blade and anvil type arrangement should work good too. Don |
Do you guys think that if I clamped the tube flat and used this 52tpi blade it will work smoothly?
http://www2.omnimodels.com/cgi-bin/w...I=ZONR3058&P=O |
clamp it flat then cut next to the clamp block with an olfa razor knife use
wd 40 as a lubricant. Use a wood bottom block and an aluminium top block knife guide. when the blade dulls just snap off the section and you have a sharpe blade. Terry
Life beats the alternative hands down. |
