Old 02-12-2024, 03:07 AM
Hoggo Hoggo is offline
Yobbo
Default TX650 hydraulic clutch conversion.
I've been ruminating on fitting the TX650.with a hydraulic clutch actuator for some time. Originally a plastic screw type actuator was fitted. The clutch action is a little heavy for my arthritic fingers and difficult to operate as my fingers are fused. At first I modified a spare screw actuator by lengthening the lever, it worked ok, but I'm not a fan of screw type actuators, so, I set about making a hydraulic actuator. I worked out I could fit a hydraulic slave to the inside of the side over with a max piston size of 25mm, requiring a master with a piston of around 10mm. That being the sticking point.
I finally found a master cylinder that 'should' do the job: Its for a KTM and has a 9.5mm piston. Its on order and should be here in a a couple of weeks, along with a couple of banjo fittings. Fitting the slave behind the cover seemed the best idea, as it provided a good solid stop against the clutch spring pressure and would be unobtrusive.
Unfortunately, I couldn't find a clutch master that matches the brake master of the right size, so I've decided to make a feature of having non matching masters. To that end, when the clutch master arrives, I'll polish the body, and then order a radial brake master and polish that, you can't get much different than these two masters.
So, the last couple of days I've spent on the lathe and mill building a slave cylinder and modifying the side cover to fit it: Lots and lots of setting up to ensure the holes are in the right place and everything fits. Lots and lots of swearing and cursing as well.
The piston is phosphor bronze, 25mm diameter and 28mm long, drilled 8mm to a depth of 20mm to take an 8mm ball and the 8mm push rod. Turning and milling the slave was a barrel of fun: I started with a small block of 50 mm 6061, faced it and bored it out to 25mm to a depth of 26mm, then enlarged the first 6mm to 33mm to take a hydraulic ram seal. The seal has a locating lip, so, I had to grind a tool to the ssame shape as the lip to turn a locating groove. And wouldn't you know it, in a moment of senility I turned the groove at the bottom of the 25mm bore, instead of the 33mm seal bore. Oh well, I fitted an O ring to the mistake groove and I'll tell anyone that doesn't know any better the O ring is to soften the rebound.
After the bore was done, I turned the slave around, chucked it and turned down the other end to 29mm for 18mm, drilled and tapped to 10 x 1.25mm, then faced the end.
I had to mill 3mm off the 50 mm diameter end so it would fit in the side cover. Once that was done, the side cover was mounted on the mill and the 26.5mm screw actuating hole was bored out to 29 mm to fit the slave cylinder. The slave was fitted and the two mounting holes marked on the slave, then the slave mounting holes drilled and tapped to 6mm x 1.00 to a depth of 10mm, a mm or two short of the ram seal bore . The slave mounting holes on the the front of the side cover were then milled for clearance to take the allen screw heads.
The slave is mounted where the original screw actuator sat, so space was tight. It's a rather dirty environment behind the cover, so I may have to fit a cover over the seal end to keep it clear of dirt and grease. I'll also have to turn up two half circle Delrin spacers to fill the gap between the slave and the cover to make it look a little neater.
Here's lots of pics of the build.
ID:	170083   Click image for larger version
ID:	170084   Click image for larger version
ID:	170085   Click image for larger version
ID:	170086   Click image for larger version
ID:	170088   Click image for larger version
ID:	170089   Click image for larger version
ID:	170090   Click image for larger version
ID:	170091   Click image for larger version
Old 02-12-2024, 03:09 AM
Yobbo
More.
ID:	170093   Click image for larger version
ID:	170094   Click image for larger version
ID:	170095   Click image for larger version
ID:	170096   Click image for larger version
Old 02-12-2024, 10:06 PM
Looking good, Tony. BTW, what happened to toglhot? Did you have a falling out or is this a case of CRS (password)?
Old 02-13-2024, 02:10 AM
Yobbo
Still toglhot, just not on this forum. Every now and again this forum won't accept my password, so I have to rejoin with a different user name. Third time now.
Old 02-13-2024, 05:26 AM
Nice machining.
maybe I'm looking at it wrong but it looks more like once you pressurize the cylinder you are likely to push out the seal.
in general the force of the fluid should force the seal tighter against the walls, I don't see it in your design.
you need to back up the seal so it does not balloon out.
Old 02-13-2024, 12:27 PM
Nice machining.
I think the seal he used had a small lip on it, that he machined a small groove in to hold it in.
Old 02-13-2024, 03:55 PM
Yobbo
Nice machining.
Geezus, read the post!
Old 02-13-2024, 07:57 PM
Nice machining.
I see what you are seeing.
You are the hydraulic expert here. Is this a common practice to hold the seal in with the lip?
Oh, well, time will tell.
Old 02-13-2024, 09:13 PM
Normally when I make grooves for seals, I just make a square groove. My seal book tells me the groove sizes and tolerances allowed.
The little extrusion part just puts extra pressure to insure a tight seal, usually under low pressure situations. When under high pressure, the seal will conform to the groove and will try to extrude into the gap it is supposed to seal, thus blocking anything leaking. This is why it is important for the edges to be free from sharp edges/ burrs.
Old 02-17-2024, 03:21 AM
Yobbo
It's been tested at 120psi, no balooning, no,popping out, so that's good enough for me.
