Old 12-29-2018, 01:58 PM
Default Trailer
A trailer for Chris
Old 12-29-2018, 02:27 PM
Very cool Ted. Never crossed my mind for a goose neck. Have to add that to my to do list. Thanks for the thought.
Old 12-29-2018, 02:48 PM
Default This is his wright up
Chris Rahman prefers gooseneck trailers to bumper hitches, so when he built a trailer for his Polaris Ranger, he went gooseneck. The gooseneck design offers better weight distribution on the utility vehicle, just as it does on a pickup or truck.
"I see all kinds of accessories for UTV's, but never a gooseneck; yet it's really handy," says Rahman. "I can use it to haul 2 big round bales at a time."
Rahman says steering is good even with the heavy load. The trailer is 5 1/2 ft. wide and 10 ft. long with a stake bed. The frame and the hitch are 2 by 3-in. rectangular, 1/8-in. thick steel tubing. The corner of the gooseneck hitch is reinforced by a 1 by 1-ft., 1/4-in. steel plate gusset.
Axles for the trailer are equipped with spring shock absorbers from golf carts. Rahman keeps them set at their lowest setting, leaving room to ride even with heavy bales. The 22-in. tall tires bring total bed height to 26 in., and total trailer weight is about 600 lbs. empty. The vertical post for the gooseneck was fabricated from 18-in. long, 3-in. dia. pipe. A 2 1/2-in. dia. pipe inside the 3-in. pipe makes it easy to adjust the height of the gooseneck. A clevis design connects the pipe with the base on the UTV bed.
Rahman went with a clevis design instead of a standard ball to allow greater travel on rough ground. He took the bed off the Ranger and made a plate to bolt to a cross member on the frame. He attached the clevis directly to it. "I can remove 2 of 4 bolts to lift the plate up to service the air filter,” says Rahman. "If I disconnect the gooseneck, I can replace the bed and the lift mechanism without removing the clevis base."
Rahman outfitted the trailer with LED lights for loading the trailer and for backing it up. He has about $1,800 invested in the trailer. Although he isn't planning on building the trailers to sell, he admits that everything, including it, is available for a price.
"If I built another one, I would lower the gooseneck some to get more travel over rough ground," says Rahman. "My next project is to build a small camper unit that can ride on the trailer."
Old 12-29-2018, 05:07 PM
Where did you the the info on materials?
Old 12-29-2018, 05:09 PM
Here, I don't subscribe so I had to cut and paste
Old 12-29-2018, 06:34 PM
Nicely done.
I would have moved the axles up a bit more, so more of the weight
is on them, and less on the tractor.
I built the long trailer with the spring shackles welded to angle iron
with the leg turned up.
So I can slide the axle forward or back to set the tongue weight.
Old 12-29-2018, 07:05 PM
flametamer's Avatar
Several years ago a guy I know took the 5x10 trailer he used to haul his Mule with and converted it to a gooseneck. This allowed him to pull the trailer w/ the Mule to deliver wood shavings (bedding material) into the isles of the barns at the state fairgrounds. He could still pull the trailer behind his truck using a 10 or 12 in drop receiver inverted.
Dt
Sero Sed Serio
Old 12-29-2018, 07:54 PM
https://www.scamptrailers.com/showro...-layout-a.html
Uses a 2" ball.
2400-2900 lbs.
Old 12-29-2018, 11:32 PM
Scrapper Greg's Avatar
Neat setup. I'd move the axles up also.
MAGA
