  #31
Old 01-11-2019, 03:35 AM
Is a rotating excavator next ?
  #32
Old 01-11-2019, 06:38 PM
Nice design/fab work!!!
We shall see when the wheel drops into a hole while supporting 3000 lbs.
  #33
Old 01-11-2019, 06:49 PM
A 1/4 scale RC model perhaps?
  #34
Old 01-14-2019, 12:50 PM
The forks are in place. The two 1" diameter rods connecting the forks are for locating only, once it is all welded they will be removed. The attached C clamps are for counterbalance.
I have a gusset in place but I'm not quite happy with it. I am still trying to integrate the fender/shield and provide enough structure to carry the load. This gusset is not getting me there. I have some other ideas, in time one of them will prevail.
  #35
Old 01-14-2019, 01:00 PM
It is a bit confusing to see (especially if upside down) the frame of the dump box. The frame is supported by a fabricating jig that has been leveled, various bits and pieces are resting on top of it.
  #36
Old 01-14-2019, 03:01 PM
  #37
Old 01-17-2019, 11:01 AM
At this point I am developing on the go as I have no drawing of the gussets or fender. Here is what I came up with.
  #38
Old 01-17-2019, 11:05 AM
The pieces are tack welded together. The twine that is protecting the bearings from weld spatter will be replaced with copper wire as I don't think it will hold up to the heat of welding.
  #39
Old 01-17-2019, 11:20 AM
It's a beast. I don't think I can bend it if I tried. The four stiffeners placed on the forks are 1/2"x2", they made a huge difference in my confidence. I guess it weighs 150 lbs. at this point.
I am now more concerned with the durability of the swivel assembly. Remember the bearing races are not hardened. I spent a fair amount of time designing it, I don't know what else I could do short of making it larger. There is nothing I can do about it now. Moreover I don't really know if the caster will track properly or if this entire approach to dumping will even work. We shall see.
  #40
Old 01-17-2019, 11:40 AM
That is some damn nice craftsmanship!
