Old 12-27-2020, 01:07 AM
Default Help Identify Compressor Pump
I bought this from the scrap yard about a year ago and am now looking to make something of it. It would be nice to know the manufacturers as I am putting it to use. I initially thought it was a Champion but closer examination leads me to believe it is not, at least not a late model Champion. A sticker on it says made in USA.
I would guess the pump to be rated for 5 HP. I found a 5 HP motor the same day that is painted the same color.
ID:	158973   Click image for larger version
Old 12-27-2020, 03:54 PM
460 Delta's Avatar
460 Delta 460 Delta is offline
Champion S-20 single stage.
Perfection is the enemy of good enough.
Old 12-28-2020, 04:59 PM
The S-20 pumps that I have looked at appear to be different. Counting the number of cooling fins on the cylinder, mine has 10, the others have five.
Old 12-28-2020, 05:21 PM
460 Delta's Avatar
A new and improved s-20 Champion? I have a s-20 with the wide fins like you have seen in pictures but the crankshaft housing and the inlet and discharge valves look the same.
