![]() What is my best bet to repair this? Should I use some sort of JB weld, or should I weld it up? What is the correct process to weld on a tank like this? Rinse with water and then fill with water before welding? Thanks Wayne |
If it is full of water and leaking you will not be able to weld it. It was diesel just rinse it good and weld it. If you are paranoid purge it with Argon or CO2 first.
The best way to clean it is with a steam cleaner or hot water pressure washer-pull all the plugs and just leave the wand in there for 1/2 hr or so and your good to go, or you can have your local radiator shop hot tank it for you. Plug all the openings and put 2 or 3 psi air pressure in it and use soap to check for leaks-I use an old vacum-fuel pressure gauge so I don't over do the pressure. If a weld is cracked grind it out and reweld.If it's a crack drill the ends(so it doesn't spread) and weld it.If it is wore thru then you can put a patch over the thin spot. Retest when your done to make sure you have it.
HTH Bill |
I'd tig weld it, than coat the inside with POR 15, for a permanet fix.
I will mention that I do more than a few fuel and oil tanks, yes gasoline too, but my safety proceedures for all tanks are considerably more thorough and rigid than the quote above. I don't plan on becoming the next statistic or story. |
I think that calweld & the hat just Overly Paranoid............. Diesel Fuel is Pretty Hard to Get Going,..... Last summer I needed a Sluiceway,+ Had a couple of Home Fuel Tanks,....... ![]() Both tanks had a few quarts of Fuel left in them,....... About 1/2 to 3/4s thru cutting them up,... There'd be a small Fire,+ Flare up,..... I let the fuel burn off,+ slowed the Flare Up with a Garden Hose,......... 1 afternoon got me to Here........ ![]()
Any Grease is Better, Than No Grease At All... |
Diesel fuel tanks are more forgiving than gasoline or other aromatic solvent tanks are , but they can still catch fire . I do purge any tank if it has had in the last few months or still does have any fuel in it , better than burning down the shop .
![]() Tank sealers , Rest-O-motive Labs in New Jersey Makes U.S. Standard Fuel Tank Sealer , I have used this product in the fuel tank on my portable buzzsaw and have been extremely satisfied with its preformance to date , it sealed the small re-occuring leak on the soldered seam of the tank and made it easier to inspect the interior of the tank for foreign matter . If you decide to go this way you will need to follow the directions to the letter , Do not try to short cut the process or you will have a mess on your hands !! ![]() ![]()
Tools to Men are like Shoes to Women , you can never have too many !! ![]() Used diesel engines are an adventure anyway you look at them !! ![]() Miller XMT-304 Multiprocess Miller 10-E Wire Feeder Miller Spectrum 2050 Plasma Cutter Hobart AC/DC stick welder Hobart 175 Mig Craftsman O/A set Turbo torch and B-tank |
The person who said "no guts no glory" is probably dead. There is no such thing as too much ammo.....the real problem is a target deficency. |
**************************************** Lincoln AC225 stick welder Lincoln HD100 WeldPak flux core wire feed welder Three of the cheapest grinders money can buy |
I once built a 2'x2'x8' diesel transfer tank out of diamond plate alum for a truck bed and the owner came and got it and filled it up and ran it a few days and came back and said it had a pinhole in one of the welds. The fuel was down below the hole so I just had him to run the truck up on a crib block so the fuel would be on the other end. Just took the cap off and ground a little where the hole was and welded it with prob 50-60 gal of fuel in it
James
When the weldin' hood drops the Bulls**t stops SAGO MINE TRAGEDY WE WILL NEVER FORGET 1-2-06 |
