![]() Damned if I can find this type of mechanism anywhere and I'm not even sure what it's called. I tried googling "cam lock", "trailer door lock", "t-handle trailer door lock", etc. All I can find is the t-handle itself with the associated little square rod. I need the actual mechanism. Any idea? |
Nope, nothing on there like what I am looking for. Been on all the trailer and hardware sites I can find.
We use these all the time. Do a search for "multi-point lock"...I think that's what you're looking for. T-handle on the outside has a 5/16" square shank that goes into the latch mechanism on the inside. Turning the handle rotates two arms which in turn connect to two rods which extend to the sides of the door.
Not much to go wrong with these. The rods are usually held into the arms with cotter keys--have they fallen out? Does the 5/16 shank turn when you turn the handle--pretty hard to do but it could be broken...
Like this?
http://www.realworktrucks.com/catalo...47/image/9269/ Or this? http://catalog.mooreindhardware.com/...ing-t-handles?
"I was raised with you do things because its what you should do. I never expected anything in return." -----DozerDan Last edited by TEK; 06-01-2016 at 03:29 PM. |
Looks like the lock off of an old fiberglass pickup topper
Garage door lock?
Scott |
What part exactly is broken? Does the 5/16 square rod turn with the handle? The rest of it is fairly simple and could fairly easily be fabbed up.
