#31
![]() ![]() I know what you mean about the cranking up of those heads. Down isn't quite as bad but up, ugggh. If I used my mill/drill more, I'd consider that modification. What brand of chili, or do you make your own? ![]() Dave
Hoocha Momma!, who chop-id-da cheese? |
#32
![]() Now its an official Texas build.............. ![]()
jack |
#33
I have two more videos that illustrate a side purpose to this experiment.
I will post one per reply. When I crank the head up or down manually, it always swings wildly from side to side in addition to hurting my ribs. ![]() So I as wondering just how much the motorized lift might affect that. Not hoping, just curious. 1. So I set up an indicator and a 1/8" rod in the spindle. 2. the video, test 1 You can watch it wander around. ![]() Now, this is a huge improvement over hand-cranking; the side torque from that might swing Mildred around one to two inches so this is an improvement but register is register and it definitely still loses it. No surprise there. Now I need to walk Wilson to the park and then go work an hour or two. I'll post the other little experiment tonight.
#34
You know, I'm not entirely happy with it because the chain wants to catch now & then. That appears to be caused by the slop in the mount; I had to design some slack into those bored out hex bars to be able to maneuver the bolts through them and then it's compounded by the slop in the bolt holes in the head casting. This allows the motor mount to jerk up slightly - less than 1/8" - when the head goes down and then jerk back down when it reverses. And that means that no matter how I try to take the slack out of the chain, it comes back on one side or the other in operation. You can see that happening in the videos. I don't see a practical solution and I don't see a better place to mount the motor. But it works so I have to be satisfied about that. In fact, I am damned pleased about that. ![]() Quote:
Old Man would be ripping on about the "ratio" on this one. ![]() Quote:
The controller is rated at "5 amps max". I'm using the same model to run Charlie's 1/3hp dc motor. Quote:
I tended to bang my ribs against the table. Quote:
![]() I'm really not particular. ![]() One chili dog doesn't require very much chili and I used to balk at opening a can just to use such a small amount. Madam came up with a solution to that. ![]() She suggested that I spoon the can of chili into an old plastic ice tray & freeze it. Then pop the frozen cubes into a plastic bag for storage in the freezer. That chilicheese dog had one thawed chilicube in it.
#35
Kudos on Mildred's project, I'm sure she is as pleased as you are. I am also much impressed with the chili cube solution!
The older I get the more I know and the more I know the less I understand. "I'll keep my freedom, my guns and my money. They can keep the change." |
#36
You could add an adjustable idler sprocket to take up the chain slack. If it was mine, I'd leave it just like it is, since it looks to work well. It sure makes moving the head up or down a real easy task. Is there a powder coat coming in the future?
#37
Chilly, chili cubes. I love it!
![]() Dave
#38
Great job Cutter. I don't read often in the Machining section 'cause I don't understand most of what is said/defined here so that is why I haven't commented before. I can comment on the "redneck flap stick"...you had posted about this some years ago and it is a tool I have since used many times in my meager endeavors, so thanks for that. Again, great job and I enjoyed the read. |
#39
Buttermilk for smoothies, too. ![]()
madam X - Site Empress for Life Director of Policy, Inane Matters (by appointment) Rated M for MAGA |
#40
![]() No. That means 'not yes". Hell no. It might get some Permatex slopped on it if I have reason to dismount the thing. Quote:
I use it pretty often too. And thank you. ![]()
Tags |
gearmotor, harbor freight, head lift, mill/drill |
