![]() Monday's job will be the hanging of the burner on the front of the boiler. This will involve the use of a Harbor Freight engine crane, a plasma cutter, welders, etc. I made the burner adapter ring, http://www.shopfloortalk.com/forums/...ghlight=burner the boiler makers who are putting the tubes in, welded the plate on the front of the boiler, now its the start of the assembly part of the job. The fact the job is in Vermont is not adding any excitement to this job, the office is sending up help, a part time worker, a retired GE steam turbine technician/welder. He is a great guy, but wouldn't know a boiler if it bit him on the ass, but a guy who can do just about anything mechanical, if you lay it out for him, it will be perfect when he is done. I'll start posting pictures tomorrow of the daily progress, so you people can suffer right along with me. I rank this job somewhere between a root canal and a gun shot wound to the head, the people who a running the job are very decent people, but are not proper boiler people. Oh Fun, Oh Joy!!! |
Please post LOTS of pictures. This looks interesting and is a subject I know very little about.
Buy it cheap and stack it deep Klaatu barada nikto |
What part of Vermont will you be in? With the roads in some areas still washed out you might not be able to get there from here. You'll have to go someplace else first.
Make over, make do, or do without Why do I have to press one for English when you're just gonna transfer me to someone I can't understand anyway? Grant me the strength to accept the things I cannot change, the courage to change the things I can & the friends to post my bail when I finally snap! |
Arrived in Vermont, at about 7:20 am, and stated to disassemble the burner, so it can be installed. All told the burner weighs about 1000#, too heavy to install in one shot. Had burner disassembled into 2 main pieces and a few minor sub-sections by about 10:45 am. Hung the burner housing and refractory ring, by about 12:30 pm, had the other main piece hung by 2:30 pm, then called it a day.
1 - the burner out of the crate 2 - crate with control cabinet and refractory ring 3 - air damper shroud removed 4 - air damper and FGRR inlet removed 5 - some of the parts removed jack |
6 - 300# refractory throat ring
7 - burner housing 8 - burner up, test fitting FGR inlet 9 - air damper assembly 10 - other side of burner Job is already behind schedule as boiler makers and refractory people are not done yet. jack |
That ought to get ya' hot under the collar.
"Freaking" is what you feel when things go wrong. The other word really refers to what happens when things go right... That one is only bad if it's against our will". ![]() |
Jack,
That room looks way too clean and orderly. How do you find anything? ![]()
Trying to make retirement as much fun as 40 years of working ![]() So far,,,I'm succeeding. ![]() "I don't care if you like me or not. I'm not even on Facebook." ![]() |
jack |
LOL Jack I have been in a few boiler rooms and knowed that wasnt one ![]() ![]() ![]() Rick
if it aint broke fix it till it is Proud member of the garbage gang and sub chapter Mole Hill gang ![]() Politically Correct : A term used for whiny pu**ies that need sh*t sugar coated . |
How much fuel/hr is used to make 42 million BTU/hr?
Thanks for the show.
why do all my favorite pastimes, except one ![]() |
