Walker Chief slag chipper and floor sweeper, Ironwood Artistic |
The Rigid 300 has a 1/2 hp gearmotor with 38 rpm output.
If you want a super compact drive, the gearmotor (motor + gearhead all in one piece) is the way to go. May be hard to find the right hp & ratio ... you'll need about 50:1 reduction using a 1725 rpm motor. A somewhat larger package, but much easier to put together, would be a 1.5 - 2.0 hp 3ph motor (cheap & easy to find on Craigslist or eBay) + a VFD for fine speed control. Use about a 3" sheave on the motor & a 12" sheave on the roller drive, giving 4:1 reduction, which the VFD can then reduce another 10:1, giving 40:1 total reduction. That would produce about 43 rpm (and you can go slower) + reversing. For the motor, something like this. For the VFD, this or this would work fine. About $100 for the motor (maybe less on Craigslist) + $200 for the VFD, + a couple of sheaves & a v-belt. The reason that Rigid uses a 1/2 hp motor is that all the speed reduction is in the gearhead. To do the same with belts & a VFD means using the larger hp motor.
Barry Milton - Please email or PayPal through PrecisionWorks.co PM's are disabled ![]() |
Maybe an old winch(12V), or an old hoist?...
Get Old Man to send you the gearbox off a circle sprinkler.
Maybe Randy could get it close. ![]()
If you could find something like this one. Right at the present I don't have any idea how slow it is but she is slow. It is a double reduction and uses 120 volts and will reverse.
You have anything with hydraulics you could run a hydraulic motor off of power pack, tractor, wood splitter, etc? Control valve and some plumbing+couplers and your set to jet.
You do the best you can with what you've got. ![]() |
Walker, I have this HF Electric Pipe Threader. You would have to make an adapter for it but for $150, it should power your roller.
Dan
Tools to Men are like Shoes to Women , you can never have too many !! ![]() Used diesel engines are an adventure anyway you look at them !! ![]() Miller XMT-304 Multiprocess Miller 10-E Wire Feeder Miller Spectrum 2050 Plasma Cutter Hobart AC/DC stick welder Hobart 175 Mig Craftsman O/A set Turbo torch and B-tank |
Keep your eye out for a mobile home anchor machine. Some guys use the Ridgid 300 but they make a dedicated machine. They sell new ones at Northern Tool. They are $900 or so new, I found mine for $75. I see them on Craigslist occasionally for under $150. These machines have a ton of torque, I've had anchors hang up and, when I had a good enough hold on the machine, twisted them into pretzels. If you are off balance when it grabs you are in deep shit, even if you can kill the power it takes a while to wind down.
I meant the 700 Ridgid...http://www.ridgid.com/Tools/700-Power-Drive Last edited by bgott; 01-04-2010 at 09:46 PM. |
It looks like a gear motor would be ideal. There is an old drill and clamp type press that was my grandfathers over at my dads house. As I recall it was super low geared and would twist your body in half if it stuck. I'll swing by there tonight and see if it is still around and would be a viable candidate.
