He claimed it was in great condition and I didn't have time to look it over until days after I bought it.
Any idea how to fix this? https://www.youtube.com/watch?v=bBsq5axRzzc The lever to release tension on the pulley isn't connected anymore. I assume I have to pull the whole head off the shaft and then reconnect something, or replace a broken piece? I wish this was the only thing wrong with the drill press. This is the priority to fix ![]() Last edited by staybusy; 08-20-2022 at 04:28 PM. |
Can you pull the shaft all the way out? Does the shaft with the black knob screw all the way out, and does it get tight when screwed all the way in? The chrome handle is not to release belt tension. It is to apply belt tension. Are the belts tight or loose now?
Chris One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors. Plato LET'S GO BRANDON!!!! B biggest I idot D democrats E ever N nominated Last edited by milomilo; 08-20-2022 at 06:32 PM. |
guessing if someone replaced the belt that may prevent the handle from tensioning the belt as in the belt may be too long. (just a guess).
Referring to Gerry's Jet .pdf, it looks like #30 fell off of #29 and is probably sitting in the casting next to the post. Looks like it is held in place with a set screw and once installed, acts on #98 and center pulleys.
![]() Thanks for the diagram that will come in very handy. I'll try to pull the head off next time the sun's out (few days of rain incoming). Quote:
I'll test out the black knob screw and get back to you. The belt is currently tight. I'm trying to swap it over to the slowest setting. |
Every forum has it's franz
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. The countries whom the gods would destroy they first make green. Rex Murphy Last edited by Shade Tree Welder; 08-22-2022 at 11:35 AM. |
I like your thread title.
Maybe try it out before you buy next time. ![]() All these DP's are the same, no matter what the label on them. Look at #29 on the drawing to see how it functions. It's no big deal to lift the head off and work on it if needed. I can post a link to a hammer if needed ![]()
