Finished up some cable reels for the soon to come welding flatbed. Here's some pics and a pdf of the sketch. The reels are 15" circles and a 15" piece of 1 1/4" pipe with bearings ove a 3/4" CRS round bar. The reels are not wired there is a partial chain link that the wire will hook under and then roll them up. I tried to come up with a "fancy" locking mechanism to keep them from unrolling but opted for two pieces of black rubber bungee with the slots for adjustablity and just stretch it over the handles locking them together. I also plan to cover the whole works under a vinyl bag. I had the diamond plate steel and 2x3 tube and 1/4" plate had to buy the pipe and 3/4" bar and all hardware totaling around $75.00 TB
Millermatic Passport plus and spool gun Millermatic 250 Miller Bobcat 250 Hypertherm 65 PlasmaCam 98z Enco 7x12 bandsaw Delta Industrial 16 1/2" Drill press Lincoln precision Tig 275 |
Them look purty dich
on my reels I welded a piece of 1/4" x 1" to the sq tube and drilled holes on the sides of the reels and uses hitch pins to keep them from unrolling one thing that I see that may cause a problem is the small diamiter of the pipe and the leads been coiled to tight around that small of a radius, it may be all right though. what is the other 2 reels for ext. cord and hose? and how do you plan to hook them up? Great work
When the weldin' hood drops the Bulls**t stops SAGO MINE TRAGEDY WE WILL NEVER FORGET 1-2-06 |
Looks good, Travis but I'm with James - wondering about that hub diameter.
cutter Housekeeping Staff: the Gatekeeper Director of Policy, Syntax and Grammar (by appointment) "Dr. Chandran, will I dream?" Just Keep Walking "I am not a body, I am free. For I am still as God created me." |
At this point the other two are for a regular extension cord and extension leads. I'm just going to unroll them all the way and plug them in with the twist locks. Not ideal but couldn't come up with a clean easy, cheap way to leave them connected and most of my mobile work requires all my leads and then some. I thought about the small diameter too but leads seemed to wrap fine are you worried about damaging the leads over time by wrapping them that small? TB
i made a big air hose reel and i ran the end of the hose out through the center pipe and the hose sticks out so you can hook it to another air hose,the air hose coupler will swivelon a lead you just unhook the lead to roll it up.
Randy |
yes, I think over time of been wraped around the small diamater that the strands will eventually break or weaken
