Old 09-23-2012, 08:03 AM
Default More John Deere crumple zones
I have a desperate customer who has a 9600 combine tire and rim with a cracked rim.
They only want $2600 to replace the rim.
I can drill the cracks and weld it up, but it is busted around the bolts area.
I can only think I have to cut out and replace the metal in the bolt ring.
Aww, crap. One picture is of a ring roller a guy gave me yesterday. Sorry
ID:	95921   Click image for larger version
ID:	95922   Click image for larger version
Old 09-23-2012, 08:19 AM
rickairmedic's Avatar
SFT HVAC Guru
Well Gerry that would appear to be 2 totally differant types of Sucks .
The guy with the combine ( sucks to be him ) .
The " Free Ring Roller " You Suck .
I would say on the rim as long as the cracks dont go through the lugg bolt holes go ahead and drill it and weld it up . Then again you do have that fancy plasma table .
Rick
Old 09-23-2012, 09:29 AM
Windy_Acres's Avatar
Chairman of the Headboard
For his sake, I hope the combine is done working for the year (which I'm assuming its not, and the clock is ticking). They just hit the fields down here this week. $2600 does not surprise me, considering the color of it.
Can you really weld that, and permanently fix it ?
If it was mine Id be buying a new rim, reluctantly, just guessing there is a metallurgy problem with that rim, either that or the lugs where not evenly tightened (and a couple where loose for a while ?) Not sure how many acres hes harvesting, but it is usually cost prohibitive to have a combine go down when its time to pull. Ive seen my neighbor screw up, and in mid January pulling corn out of a field that has 6" of snow in it, and drifts 36" deep.
BTW, you suck on the roller , well done.
Old 09-23-2012, 09:59 AM
Gerry, I had the exact same repair way way back when on one of my GD 8800's with duals.
I did as you are thinking, carefully cutting out what flat plain I could to very carefully be able to piece back in. I beveled both sides and for lack of a better rod on a weekend ass deep in Sbeans, I had to use low H all the way. I did stop drill a few cracks that were radiating out, but welded everything back both sides with low H as well.
4 years later the combine was sold with the same rim and repair. Had no further problems on my end, and did tell the buyer about it.
Old 09-23-2012, 10:51 AM
Last summer I did one the same as LW, double beveled. Had a few more cracks in it than yours apperas to have. Stuck with 3/32 7018 all the way. It was on a swather that is still running fine this summer with no more cracks.
Cause was loose bolts that allowed the flex on the wheel. Only one had cracks in the hole. Had to do a little clean up in the hole to smooth it out. I did heat it up around 300F during welding and left the welds slightly proud of the base metal.
The whole job was lots less riskier than the 4" wide 1/2" thick main leaf spring I welded up a few years back on an old Reo.
Almost forgot to ask. Are you gonna use the ring roller or is it scrap?
Old 09-23-2012, 11:11 AM
Gerry,
It's been a while since I fixed anything like that but it can be done, especially as a temporary repair when a machine is down. And, as LW notes, you could get lucky and have it last for a while. In any case it should be enough to get your customer through the balance of the harvest. Does this happen to be the same one who had the problem with his header when I was there?
One thing I've done is to cut out a ring of 3/8 plate that fits tight on the outer face of the rim--so the lug nuts would pull up against it--and drill it for the same bolt pattern. Stitch weld it to the rim and it'll take some of the load off the original flange. More work but it will probably buy your customer some more time...
PS...check your email lately? I sent you a couple links...
Old 09-23-2012, 12:22 PM
Yes, it is in the middle of harvest The combine had 5000 hrs on it when I worked on it a couple years back.
I have already started cutting out the replacement ring, and I've cut out the parent metal. See below.
Due to my power supply issues cutting 5/8 is a bitch, I have the water heater in the house shut off, and I can't run the compressor when I am cutting so it is slow, build air, burn, stop, build air...
Noooo, I sure am not going to scrap the roller....I'm not that dumb I saved a gear box from that blow deck I scrapped, which will be perfect reduction for it.
I also got 2 - 70 gallon propane water heaters as well for 300 bucks from the same guy.
ID:	95930   Click image for larger version
ID:	95931   Click image for larger version
Old 09-23-2012, 12:23 PM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
Would it be possible to weld then sister a ring on top?
Old 09-23-2012, 01:02 PM
Just a caveat, Im assuming you know this, but your not supposed to weld or cut on a rim with a tire mounted, dont take that as an insult.. I started out life in a tire shop, and never would have thought twice about it. Im assume you guys have covered that in the past, and Im assuming you got the tire off that rim already.
This is just one of the videos Ive seen on the subject, sometimes it takes a day or two for the tire to explode. There is one by brigdestone, I think, shows in the interior temp rise overnight. IIRC, I think removing the schrader valve does little to prevent the possible explosion.
There are better and more explanatory videos on youtube, but being that my connection is about a 1/3 of dial up, its hard for me to preview or search videos. This is basically the first one I cam across that addresses the problem. I recall a catalytic process of the heat generated with the material of the tire, that causes a fast rise in pressure. This video skims past it, others detail the process.
http://www.youtube.com/watch?v=pNZ4siYGkag
Old 09-23-2012, 02:58 PM
Wasn't trying make fun of you just wondering if I needed to start crying today. Glad the pressure is off now. I'd love to find one like that around here. I'd even pay for it.
