  #61
Old 05-26-2020, 11:02 AM
Originally Posted by Tim KS View Post
Are you planning on using a pitless adapter?
I expect the pump guy will do that when he gets here this week.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
  #62
Old 05-26-2020, 11:29 AM
Went to Scottsbluff, NE yesterday to pick up fittings for the well pressure tank. Maybe we got all the fittings we need?
If like most of my projects, either about twenty to many, or short one.
  #63
Old 05-26-2020, 11:35 AM
As you can tell from my earlier post, I expect one short or wrong size.
B biggest
I idot
D democrats
E ever
N nominated
  #64
Old 05-29-2020, 08:33 AM
Pump guy has not shown yet.
B biggest
I idot
D democrats
E ever
N nominated
  #65
Old 06-03-2020, 02:12 PM
Pump guy is here. He dug the trench from the power pole to the well. Trench started at 2' at the pole and ended up at the well at 5'. 1 1/2hp pump to go in.
The trench will have both the power at 2' deep and the water line at 5' deep.
ID:	156359   Click image for larger version
ID:	156360   Click image for larger version
ID:	156361   Click image for larger version
ID:	156362   Click image for larger version
B biggest
I idot
D democrats
E ever
N nominated
  #66
Old 06-03-2020, 06:50 PM
Pump guy is here. .
Now Scott can relax.
  #67
Old 06-03-2020, 08:31 PM
I wish. Now he wants me out there tomorrow to put the power lines in conduit up to the well. About 60' worth. It is 4/0-4/0-2/0 inside 2" conduit. Tight fit but doable if you slide on one section at a time and glue joints as you go, then drop it into the trench. The 90 degree elbows are the hardest. Once that is done he will use his tractor to push in the dirt.
B biggest
I idot
D democrats
E ever
N nominated
  #68
Old 06-03-2020, 09:20 PM
Why are you using 4/0 cable to power a 1.5hp pump?
  #69
Old 06-03-2020, 09:28 PM
Thats a 200 Amp service entrance . :-)
Sure doesn't need to worry about IR drop for the pump. That MAY be "over filling" the conduit. I don't have a code book any longer.
...lew...
  #70
Old 06-03-2020, 10:05 PM
It is main service wire for the shop. for now it goes to a temporary panel. The excess wire will be buried just before they do the concrete. Pump runs off a 220V 20 amp breaker amp feed from the temporary panel for now.
B biggest
I idot
D democrats
E ever
N nominated
