Old 12-29-2016, 08:41 PM
Default Deburing tool
What do you all use for deburring machined parts? I use a combination of a triangular file, with the file teeth ground off, and a flat file? I expect there is something better.
Woodrow Wilson
Old 12-29-2016, 08:58 PM
digr digr is online now
Thats what I use, I have the Solid Blade Triangle Scraper
Old 12-29-2016, 10:32 PM
A basic Noga tool covers probably 95 per cent of what I do. Of course I have files and scrapers for special applications but the Noga gets used the most. For larger stuff where access is easy I'll sometimes use a die-grinder and a small flap wheel. Deburring is a huge "extra" cost so I'll always do what I can to speed up the process...
Old 12-30-2016, 08:52 AM
Shaviv has deburring tools like the Noga and a number of specialty tools.
http://www.vargus.com/shaviv/
http://www.vargus.com/shaviv/templat...d=25&pageId=54
Old 12-30-2016, 09:19 AM
I ordered one. Looks to be a little faster than my scraper. Thank Keith.
Woodrow Wilson
Old 12-30-2016, 10:30 AM
Yep the "deburring" tools work great and I use one on all the aluminum parts that can be made to fit. but on the steel I usually just use files (shaped as required, flat, triangular, round)
...lew...
Old 12-30-2016, 10:46 AM
alchemist's Avatar
I use a half round file or a rat-tail.
Old 12-30-2016, 11:53 AM
If unable to flap wheel I have always used a noga style .Now if I can find it.I believe in tool box in U haul unopened since 2005 .Everybody has a set for home and one from work right ?
Old 12-30-2016, 03:01 PM
Originally Posted by USMCPOP View Post
...Shaviv has deburring tools like the Noga and a number of specialty tools...
Yeah, their lines are pretty much identical. I think some of the cutters interchange as well--we have an assortment of both.
...Looks to be a little faster than my scraper...
For some things they definitely are....
Originally Posted by Lew Hartswick View Post
Yep the "deburring" tools work great and I use one on all the aluminum parts that can be made to fit. but on the steel I usually just use files (shaped as required, flat, triangular, round)...
As with many situations it's necessary to have an assortment of tools available--we use them all at one time or another. When I'm turning stuff on the lathe I always break or chamfer any edges I can while the part is still in the chuck...
Old 12-31-2016, 08:06 AM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
I use a Noga quite a bit for insides and recently set up a set of scotchbrite deburring wheels on a bench grinder for outsides
