Old 04-17-2010, 01:30 AM
AJinNZ's Avatar
AJinNZ AJinNZ is offline
Default Case hardening.... take one
In another thread I asked for help with a lathe chuck runout.
In the process of getting that sorted I discovered that the cam locks were mild steel and burred/scored.
So I could get a solid lock with the cams I first tried to get new ones with no luck. Commercial case hardening is spendy, so I am doing it myself. ( I hope )
I cleaned up the burrs and scores from all three cams and gave a modest polish to all. On one of them I left a small burr to file off later so I could get an idea of how hard they had become. ( pic 1 )
I lit the forge and got a deep bed of coals going with an overhang at the back. If it worked properly the cams would soak in the heat, under the overhang, with little oxygen present to create scale.
Name:	case harden start.jpg
ID:	59892   Click image for larger version
ID:	59893   Click image for larger version
Old 04-17-2010, 01:35 AM
AJinNZ's Avatar
Some more pics of the process
The cams in the fire with flash on and off. Sorta lost some detail both ways so I did both.
The cam just before going into the charcoal pack
All three cams in the tin before being covered with more charcoal.
Now I wait till tomorrow and see what happened. If it failed then I will just reheat and try again, probably with a longer heat by putting the tin in the fire to keep it hot for as long as possible.
Hopefully I wont need to do that.
Name:	cams heating.jpg
ID:	59895   Click image for larger version
Name:	cam heat two.jpg
ID:	59896   Click image for larger version
Name:	case harden hot.jpg
ID:	59897   Click image for larger version
Name:	case hard tin.jpg
Old 04-17-2010, 01:49 AM
Good luck, AJ. I sure hope this works for you.
Old 04-17-2010, 02:25 AM
akabull's Avatar
akabull akabull is offline
Maine-iac
I know absolutely nothing about hardening so excuse my ignorance....don't you have to put them in some sort of liquid to harden them? (i thought i heard this once)
Chris in Maine
Old 04-17-2010, 06:47 AM
AJinNZ's Avatar
You would use an oil or water quench on carbon steel.
Mild steel wont harden due to the very low or non-existant carbon content.
The case hardening process allows enough carbon to get into the metal surface to create a harder shell. The longer it has to be in contact with the carbon source, the deeper the case.
The unknown part is I havent done this before so it is all 'try and see'.
Thanks Cutter. I will find out in the morning.
Old 04-17-2010, 06:54 AM
Setup boy's Avatar
Setup boy Setup boy is offline
Press One for Trash
This is the essence of learning coupled with listening. We will wait and see which is what this sight is about. Thanks for sharing AJ.
Thank you,
Tom(Reformed Post Whore)
This legislation will have the effect of addressing that mal-distribution of income in America."
Sen. Max Baucus Montana
Do you want it right or right now?
Ya can't polish a turd.
The Techie Geek Podcast
Old 04-17-2010, 09:06 AM
From all I've read, charcoal pack hardening requires a sealed container and a relatively long heating period. The charcoal produces carbon monoxide under those conditions. That then diffuses into the metal where the CO can react with the iron, producing CO2 and releasing some carbon. The process takes quite a bit of time depending on the depth of hardening required - hours and hours.
Don't know if you can access this book:
http://books.google.com/books?id=Xh8NAAAAYAAJ&pg=PA562
If you can get some Kasenit hardening compound you'd save a lot of time and trouble. It's primarily Sodium ferrocyanide (yellow prussiate of soda).
Old 04-17-2010, 09:42 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
The studs don't need to be hard. See where the cams are binding and relieve that area with a stone and die grinder.
If you really want to harden them, which apparently you do, get some casenite. It will do the job.
http://flagstaffpermaculture.ning.co...dium-caseinate
Old 04-17-2010, 06:32 PM
AJinNZ's Avatar
I put the cams into a tin with a lid, so hopefully the seal will be adequate.
If the length of time in there was not enough then I might have to use the kiln to maintain a much longer hot phase.
I tired to get kasenit, but it is unavailable here and the only other compound I can get ( called 'quick hard' ) is 70 bucks per pound. I decided to pass on that one......
The cams were not binding. As they reached a full lock on the chuck studs, instead of just pulling up tight they scored and burred over due to the studs being harder and the cams being soft as butter.
I could clean them up and end up in the same boat after swapping the first chuck.
I dont need full on HARD for the cams, just enough that they work as a cam and not get ripped up in the process. These really were soft as butter.
Old 04-17-2010, 11:58 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
I really hope this works for you. Jerry
