Old 03-24-2010, 01:38 AM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
Default Heat treat
I have severl large bits I am unable to use because of the large taper.I would like to turn them down to be more suable. If I heated the taper to a cherry read and allowed it overnight to cool would I be able to machine it.
Old 03-24-2010, 03:56 AM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Yes, but you may have issues with it warping with an uneven heat. If you have a self cleaning oven these often will get hot enough to anneal. (just make sure there is no oil and momma-bear is gone). If you are limited to torch heating, I would chuck it in a drill press or something and heat while its turning then bury in kitty litter. Annealing is best when you can heat, hold, and then cool slowly.
How are you going to harden afterwards?
Old 03-24-2010, 07:06 AM
I'm going out on a limb here, but assuming you mean large drill bits,
and you want to turn down the morse tapered end.
You ussually don't need to do anything, just turn them.
I have done a couple of them, the ends are not hard.
You will definitely find where the hardening starts though,
when you turn them, ussually up into the flutes a little.
Old 03-24-2010, 07:33 AM
OLD MAN's Avatar
Nobody was faster
Did you put tin around the bit to protect it from the chuck?
Old 03-24-2010, 07:43 AM
We always used thick pieces of copper, about 1/16" thick,
was wrapped around each jaw (to hold it in place).
I think you could flatten some 1/2" copper tubing.
Old 03-24-2010, 08:05 PM
Randyjaco's Avatar
The shank of the bit is seldom hard. I turn them down on the lathe frequently. HSS tools will work in most case, but Carbide will just about guarantee success.
Randy
Old 03-24-2010, 10:05 PM
Silverback's Avatar
Silverback Silverback is offline
now why the heck did I repeat the part about annealing in a self cleaning oven out loud in front of my wife. I'm already in trouble and I haven't even done it yet.
that's what I was wondering
Mark
(aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
Synchrowave 180 SD | MillerMatic 211MVP + Spoolmate | Hobart Handler 135 | Everlast Power Plasma 50
1960 Bridgeport J-head | Grizzly 10x22 | HF bandsaw | Rigid 4.5” angle grinder (+2 cheapie HF ones)
BFH
Old 03-25-2010, 12:12 AM
OLD MAN's Avatar
Nobody was faster
Problem solved, I ordered a new drill bit from Victor this morning. The windmill boys will pay half and the bit will be mine.
Old 05-05-2010, 03:46 AM
clive's Avatar
clive clive is offline
As already stated you can turn the shanks easily. We used to make long drills by turning down a step and drilling a hole in some shafting a bit smaller than the drill for clearance. then silver solder the two and you have a drill whatever length you like, we used to use them for drilling out the flail element on a 8ft. rotary mower, bushing up to tne next size when it was worn. Two drills, one 4ft then swap to the 8ft. one, piece of cake.
Clive
It's So Easy
Old 05-05-2010, 06:51 AM
Ed ke6bnl Ed ke6bnl is offline
Randy
I also have turned them down with no problem. Wrap the part with aluminum can for cutting edge protection Ed
