![]() Looks to be impossible to correctly level the machine, considering there aren't any feet, just a flat surface. My floor is wood, and sloping 1/4" per running foot lengthwise to the machine. I have a similar stand underneath my mill, and it's less than vibration free. Annoying when using a boring head, or taking heavy cuts with other tooling. Gonna build a new stand (PITA time user upper) out of square tubing that has 4 distinct feet contacting the floor supports/plates. |
Just add some adjustable feet.
Chris Liberty has never come from Government. Liberty has always come from the subjects of it. The history of liberty is a history of limitations of governmental power, not the increase of it. Woodrow Wilson |
Drawing by Smartdraw |
Do y'all honestly think adjustable pads would work? I've never put one of these together.
I'm not thrilled with the flat stock under the stands, doesn't look as if it's adequate to support the thing without vibration. It's just some flats welded to the thin gage cabinet, with a pretty healthy overhang inside. If it's feasible,, I'd sure like to use the stands. |
It's a really light machine, and it actually has to be secured TO the floor. Only weighs 1100# plus the cabinets (maybe another 70-100#)
I can run plate under the adj feet, and bolt to that plate. Remember, I gotta raise the headstock about 1 1/2" to level the thing. Wouldn't be an issue if the thing didn't run all geartrains in an oil bath. Things gotta be level for the right oil flow. Suppose I could mill riser blocks for the headstock at the required angle, so's the bolt will be plumb to the stands. I can trick the tailstock end for squaring the bolts to the cabinet. |
How about a angle Iron frame to set them in?
I would ask if the problem isn't your floor.
How much bridge do you have between supports? I would try an oversized 1/2 inch plate for the machines to rest on. It should bridge multiple floor supports and provide some mass to assorb any vibration. |
I used the method you describe when I mounted the old lathe. I think I'll just have to modify the floor plate, and make some riser blocks that will be welded to the plate in place of the current bolts. The angle (1 1/2 height at one end of lathe), calculated out to somewhere around a skosh over 1*. I could get all anal, and mill the blocks to this angle, or simply make square blocks, bolt them to the underside of the cabinet, and tack them to the plate...…..then finish weld it all out after I pull the plates from under the lathe. Lot less work, and the bead will fill the 1* gap nicely. |
So, yes, the supplied cabinets are definitely usable. Seems the standard setup, it's just that I"ve never set one of these up before, and worried too much.
![]() ![]() ![]() Ah well,,,,,, When I discovered the bed wear on the resto, it was this, and never looking back. Is what it is. Woulda really liked the old American machine to see some run time. |
