Old 09-18-2021, 11:49 AM
OldRedFord's Avatar
Kibble King
Default First real project
Need to make 1 7/16 shaft 22" long with a 3/8 keyway for a bucket elevator head pully and gearbox at work. Wish me luck.
Tim
Old 09-18-2021, 12:09 PM
Have fun with it, Tim
Old 09-18-2021, 01:00 PM
astronut's Avatar
astronut astronut is offline
Good luck Tim!
Still got the shovel!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 09-18-2021, 04:44 PM
Sounds fairly easy to do. I'm sure you are up up it.
Old 09-18-2021, 05:10 PM
Good luck.
Keep an eye on the taper.... Keep mic-ing (spelling?) both ends.
Old 09-18-2021, 07:51 PM
Hope it all went well!
Old 09-18-2021, 08:35 PM
OldRedFord's Avatar
Kibble King
So first i removed the 4 jaw chuck and put the 3 jaw on. I've got it on solid info that 4 jaw chuck hasn't been off in 20 years.
The 3 jaw pulled up right to the d1-6 spindle nose but the chuck is a bit wobbly. Glad I started with 2" stock.
I took off ten thousands at a time and checked both ends regularly. When I got close to size i took lighter cuts and checked with one of the new bearings that will be installed.
Then I put the conventional mill head on the Kearny & Trecker, took the quick change tool holder from the Gorton (still in pieces) and cut a 3/8 keyway. I went a total of .173 for the keyway.
Surface finsih leaves a little to be desired but i ised my roughing insert and holder instead of changing it out and fooling with center height etc. A quock change tool post is on the Christmas list.
ID:	161468   Click image for larger version
ID:	161469   Click image for larger version
ID:	161470   Click image for larger version
ID:	161471   Click image for larger version
Tim
Old 09-18-2021, 08:55 PM
Looks good from the Interstate Ship It!
Old 09-18-2021, 09:06 PM
You can't expect a mirror finish with HR stock. Looks ok.
Old 09-19-2021, 07:55 AM
randydupree's Avatar
Why, Hell Yes!
Of course you could have put a flap disc in your grinder and smoothed that shaft out,with the shaft turning at the same time.
