Old 07-12-2021, 04:19 PM
Windy_Acres's Avatar
Chairman of the Headboard
Default Copper Anti-sieze, for ground connections ?
Doing some maintenance on my 2001 F250.
Its a documented problem on this platform, the OE grounds getting oxidized/going open over time, I think there might be a total of 8 main power distribution grounds on it.
It can get so bad, the pump of the automatic is known to WELD itself together ( rotary vane ), with enough current passing through, the trans acting as a conductor to ground, when most of the OE grounds have failed.
The 7.3PSD, being a Huei engine, it has some higher amp needs that dont get met under certain conditions ( mostly starting ) when the OE grounds start to fail.
Question is, would sealing up a factory ground eyelet connectors with copper anti-seize be a good thing or a bad thing ?
My connections, and the metal they go in are good, Im just cleaning and reassembling.
Pictures is approx to what Im cleaning.
What say you ?
ID:	161010   Click image for larger version
Name:	ground strap.jpg
Old 07-12-2021, 05:24 PM
Do I have a life?
Clean the connections real good and tighten, then paint or clearcoat over the entire connection. Anti-seize can act like an insulator.
TA 95 lunchbox w/tig
Old 07-12-2021, 05:47 PM
Ok, so thats what I was asking. I was thinking it would act like grease ( insulating on some level ) but then was wondering about why they sell it with copper in it.
Old 07-12-2021, 05:51 PM
Windy, you may consider anti oxidant grease as used in the electrics on house wiring
Old 07-12-2021, 05:54 PM
Ive got some of that on had, I think its called " ox-guard " or similar, for dissimilar metals ( copper/aluminum )
Ok, thanks !
Old 07-12-2021, 06:02 PM
That is what I use, I have tried the battery post spray and is seems to work well n my flatbed trailer. I have some left over anti corrosion grease we used on fasteners bolting the missile stages together I got when doing ICBM missile installations back in the 80s. Says it is electrically conductive.
Old 07-12-2021, 07:51 PM
Fluid film!!
Old 07-13-2021, 12:16 AM
SmokinDodge's Avatar
SmokinDodge SmokinDodge is online now
Bill I would use a dielectric grease for that connection. And probably a star washer for good measure.
Old 07-13-2021, 08:22 AM
Sure, thanks, the oe eyelets are star style, I have a tube of " Grote " branded grease ( for truck lighting ). Not sure why I did not think of that. I also have a 5 gallon pail of Fluid Film !, maybe that would be handy as a top dressing as digr suggested, in a manner that mccutter uses clear paint.
Im thinking I should but all of these different technologies in a blender and then I could enjoy the benefits of all of them.
So one thing I was hoping to learn, why do they make a high copper in anti-seize ? I think I have high zinc a/s for high temps, I was thinking the high copper style was for electrical connections, but I dont remember...
I did google this before I posted, while I got some answers, none where really specific to what I was wondering, about the copper.
Old 07-13-2021, 01:14 PM
Samcord Samcord is online now
I spray fluid film under my vehicles before winter. They also have undercoat formulation.
