  #41
Old 06-11-2022, 09:17 AM
I can't see any problem with a gas strut. You will have to make mount brackets, but even if it only boosts the window 90% of the way, the last bit to latch it up should be easier by hand.
  #42
Old 06-11-2022, 07:03 PM
I don't know the proper way to mount them at the correct spot..
I do well seeing examples and then modifying them to my cause..
But I have never seen a setup that will go the full length.. I need about 48" of window movement from bottom lock to top lock..
Question becomes how to pick them out, what is the best mounting to get the full length..
Any help would be appreciated.
_________________
Jennifer
My google+ page
DoALL 36"
  #43
Old 06-11-2022, 07:05 PM
A cable with several sheaves to get more travel for a shorter strut?
Longest strut I have found is 21"
_________________
Jennifer
My google+ page
DoALL 36"
  #44
Old 06-11-2022, 07:40 PM
Jenn, you are overthinking this (Don't go Kraut on engineering ) you don't need 17 moving parts. I found a site once with the actual math for this haven't been able to find it again yet. My advise is buy a set of long heavy ones and tack weld the mounts at a split between 1/2 and 1/3 the length of the cab window and adjust to suit till they work right. I built a trailer cover for a friend that is a painter. It's about 6-7 ft long and opens from the end he loves it. He can open it with one hand. I ended up using 3 struts to get it done. Sorry that link went straight to Amazone No Bueno
  #45
Old 06-11-2022, 07:52 PM
Over thinking.. Me Nahhh.. LOL.. It's what I do..
oI can never be accused of not overthinking and building things way too stout.
This big framed windows can be heavy.. Moves a whole lot easier with the good rollers.. But getting it off it's low position and up is a tough one until it gets at the about 50% of the top flat rail..
So what is the best way to get it there?
_________________
Jennifer
My google+ page
DoALL 36"
  #46
Old 06-11-2022, 08:07 PM
H'm you might have to give it a shove with your arm. I see struts that are rated for 200Lbs and are 24" long. This is a Redneck engineering project you can get this done easy peasy. You have sorted out waaaay more complicated shit than this.
  #47
Old 06-11-2022, 09:49 PM
Those struts can lift the whole rear door of a minivan and I'd say it is heavier than a window.
  #48
Old 06-12-2022, 03:15 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
Assuming it's an up and over window like you'd have on the front of a track machine cab?
Call into someone local selling excavators and bring the measuring tape. See how it's done on a modern machine, the principle hasn't changed much
  #49
Old 06-12-2022, 11:00 AM
Scotts Scotts is offline
got the rear window working as well..
Needed all new rollers as the original ones were flat sided..
Still need to make a lock for the up/down position..
Was hoping to use a gas strut to easy lifting it..
Hoping someone might have some insight in there use.
I am not familiar with this type of window.
Do you pull out the top and it opens above your head while you are sitting in the seat?
If so it would operate like a single panel garage door?
Like this https://youtu.be/_2ZzVGrJy90
Here is a calculator I found if this will help.
https://www.weforma.com/gas_spring_c...ion/editor.php
  #50
Old 06-15-2022, 06:24 AM
randydupree's Avatar
Why, Hell Yes!
Orr and orr has a good selection of struts,as do the junk yards,look on the mini van back door.
At the very least looking in the junk yards will give you an idea for mounting.
