Old 09-12-2021, 08:20 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
Default Cutting box in half
I need some really light channel for a job.
I was thinking about cutting 4 feet of 2x2x1/8 box in half. Wondering about potential stresses in the box though. Would I end up with two bananas?
Ideally I'd use the plasma but would I have less risk of distortion if I used a skinny disc in the grinder?
Old 09-12-2021, 08:31 AM
4-13-1949 to 5-21-2023
Expect the result would be similar regardless of the method of cutting, if there is residual stress. A zip disk would give a cleaner result though.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 09-12-2021, 08:37 AM
John, I've had the same problem and became cowardly and did not try it.
If you are moving fast enough, as you should cut 1/8 at about 90 inches a minute, the heat is negligible. You can pick it up and handle it immediately after. I'm not sure that a zip disk will put less heat into the work
But if you have a shop with a press brake near you, they can bend this channel out of 1/8" or 1/16" easily. And it will be straight
Old 09-12-2021, 10:07 AM
I have cut light square tube on a band saw and still ended up with bananas, but you should be able to straighten it out in a press.
Old 09-12-2021, 11:21 AM
You will have bananas, you can cut them anyway you like.
Tubing if first made round and then welded and scarfed, then run through the
shape rolls, square, rectangular etc. This allows for tighter radii in the corners
but induces a lot of stress but the stresses are all equal so the tubing stays
straight until you cut it.
Old 09-12-2021, 12:04 PM
You can weld 2 angles together to make the channel .I like Jerry idea best .
Old 09-12-2021, 01:08 PM
What Ron said. I have had better luck using a cut off disk in the grinder for less warpage, since you can control the heat better, but you will still be fighting the stress in the material from initial forming.
Old 09-12-2021, 02:22 PM
JohnBoy's Avatar
I suppose if I only get bananas it might be ok.
I'm welding this down as a cap on something so if they don't go too far wrong maybe I can pull them straight enough. It's not a very important job and certainly not one that justifies paying for a channel to be folded
I'll give it a lash and report back
Old 09-12-2021, 03:05 PM
Grizz Grizz is offline
probably heat would help in the cut zone. any tube that I have split tends to flex toward the solid side, until you try it and it goes the other way
Old 09-12-2021, 03:07 PM
Do I have a life?
If you were talking about Alum I would just rip it down a table saw...
HF 80 lunchbox w/tig
