![]() It looks like it went though a barn fire. It was either hot enough or had debris falling hard enough to bend the rams. All the cylinders, hoses and the valve are junk. I am looking it only for the structure. Is the steel on these tempered or heat treated? Will being severely cooked weaken the structure to a point where I would have problems? Can anyone ID the mfg or model. It could have been blue.
Director of Cryptography-Upstate NY Division |
Cav;
Just a wild guess, the second pic the pin that is in the outrigger arm it looks like the same one's that are on a Kubota tractor bucket frame for a front loader. That's about all that's looks familiar to me. Mailtrain |
I am thinking its an Amerequip brand mod 80
Director of Cryptography-Upstate NY Division Last edited by Cavalry; 03-24-2009 at 07:08 PM. |
Maybe a Bradco.
Mac ___________________________________________ One extremely happy ![]() ![]() |
other than replacing the ruber parts and cylinder seals i dont see why this wont work. the cylinders may need the tubes honed if the oild burned in them .
as to temper and what not for home/farm use i doubt you would have any trouble
" told you magnesium was fun to machine!" 1946 Monarch Hardened Wayu 18x48 (will swing 20x54) YCI Supermax 10x50 Thermal Arc 300GTSW 1.5 hrs Triumph 1050 Speed Triple Kawasaki KFX 450R |
the chrome is burned off the rods, and at least one is complete junk. I think they would leak pretty bad (externally) upon retracting
I think you have already Identified the brand, as for tempered steel all the ones I've ever welded on were mild steel, except in high wear areas. And you're right those cylinders will give trouble from now on, figure on replacing them all. BTDT!
"Banking establishments are more dangerous than standing armies. Thomas Jefferson |
Most of them that I've seen are just mild steel structures, (the other would be ductile iron) with hardened bushings and sometimes hardened pins. All depended on what kind of service life they wanted out of particular part. I sure wouldn't worry about it though for what you're going to use it for. The worst case is you'll need to do bushings and pins someday to get the excess play out of it.
Well it came home with me today. $100
![]() There is a non burned on on the 'bay right now. $2500 and still going. Gives a nice figure on how much I can spend to make this one work again.
Congrats. That's a You Suck.
A $100 is an incredible price for scrap metal that happens to be in the exact shape that you wanted. :evil::evil: |
