Old 08-13-2005, 11:44 PM
Bob Sigmon Bob Sigmon is offline
Default Metal Prep Station
I just finished my metal prep station.
I have it set up to run continuous or with a foot switch.
The knotted wire wheel really cuts through the mill scale.
Bob Sigmon
Dynasty 200DX & Coolmate 3
Miller Passport
LMSW-52T Spot Welder
O/A Setup with Meco Midget
Miller Big Window Elite
Quincy QT-5HD
Old 08-13-2005, 11:56 PM
bgott bgott is offline
Trailers for sale or rent
That is a nice looking machine. However, I see a problem, at least if it was mine. I have a tendency to feed metal to a wire wheel until I stall the motor, then back off until it starts running. If I tried using that I would probably have to chase it across the shop. Maybe some folding outriggers on the back side? Or is it just a question of operator re- education?
Old 08-14-2005, 12:03 AM
bgott,
With the four locking casters, I don't have any problems. I can push plenty hard and it does not move. I used a 3/4hp motor and I can't stop it. Worst case it has just slowed a little. Also the weight of the unit helps to make it very stable.
It's hard to see in this picture but I used 1/2" plate to mount the motor and I also welded in some 1/2" plate between the frame members below the motor mount. In all the damn thing must weight near 100 lbs.
Bob Sigmon
Miller Passport
Quincy QT-5HD
Old 08-14-2005, 12:17 AM
1911man's Avatar
1911man 1911man is offline
Co-founder, Harbor Freight 12 Step Program
Bob, I think that thing is alot sturdier than your pictures show. If so, good work! If not, you'll have more to do but it looks good to me.
The older I get the more I know and the more I know the less I understand.
"I'll keep my freedom, my guns and my money. They can keep the change."
Old 08-14-2005, 12:38 AM
Diverbill45's Avatar
Diverbill45 Diverbill45 is offline
Member Emeritus 1945 - 2014
Bob ....... Are you trying to give the guys over at OSHA a heart attack?
Where are the brush guards and the little black, red and white signs that say "DANGER" keep hands away and moving equiptment?
Job well done, looks great. I'm in need of a foot operated motor speed control unit. Any suggestions?
Bill
Bill
Retired welder/fitter of UA local #290, Portland, Oregon
Miller Dialarc HF-P
Miller 251 wire feed/ with Alum. spool gun purchased from Wyoming (Roy)
Thermal Dynamics 52 Plasma
7" x 12" Horiz. Bandsaw
Weld Craft TIG Torches
JD2 Model 3 hydraulic Tubing bender with
quite a few expensive dies
One Big Ass Mistake America
Always remember ...... a government large enough to give you everything you want is also big enough to take everything you have.
Old 08-14-2005, 02:14 AM
Mikey
Guest
Posts: n/a
Bob, that's a nice unit. I'm trying to design something similar. However, I want to use 3 grinders. Is that a jackshaft I see turning that thing?
Mike
Old 08-14-2005, 10:48 PM
Bill,
I have the little red switch. Shouldn't the red be enough?
My foot switch is just an on/off. An actual speed control is going to be hard to find depending on the motor size. Sewing machine foot pedals are a speed control but would probably be limited to small hp applications.
I didn't see any variable controls when I was looking for my switch but I'm sure that they are out there or possibly an electronics type here could recommend the proper components to build one.
Mike,
I wanted the belt for the wheels in the center while keeping the unit narrow to save space, so I did use a jack shaft
I ended up using all 1 1/2" pulley and keeping the 1725 rpm's from the motor. At first I used a 3" off the motor to bump it up to 4000 rpm's but the breeze would blow my hair back. I find that the 1725 rpm's work just fine and I have a bit better control.
Bob Sigmon
Miller Passport
Quincy QT-5HD
Old 08-15-2005, 05:39 AM
7018's Avatar
7018 7018 is offline
Send a message via Yahoo to 7018
Nice job Bob,It looks like it will do a great job!!
This post brought to you by the bringer of chaos, doom, change, and technology... Asker of questions, challenger of assumptions, solver of problems and share-er of ideas
Old 08-15-2005, 07:21 PM
TJJ TJJ is offline
Bob
Beautiful work. Seems like it will be very useful the way it's set up.
How about some epoxy paint
Have fun!
tjj
Old 08-15-2005, 07:42 PM
Boogity's Avatar
Boogity Boogity is offline
Really nice job Bob. I like having the wheels out in the open so a guy can make good use of them. Those guards just get in the way.
Is the motor mount plate on a big hinge? Is the motor weight your belt tensioner too?
Let's see some pics of your paintjob.
