Old 02-26-2009, 11:18 PM
dmerd dmerd is offline
Default The Notcher
Hi,
Here is some pictures of the notcher I made and used on the chair project. The wooden one I made for a protype. The first one I made out of aluminum and then one out of steel. Gave the aluminum one to a friend of my that has a welding shop that gave me the aluminum stock. They are adjustable up and down on a dovetail to cut a notch off center. Then I made 2 more, gave one to my son. They are solid mounted and only cut on center. They will all notch up to 2" pipe. I got the idea for them from http://www.medfordtools.com/notchmaster.html
Later,
Dave
ID:	42574   Click image for larger version
ID:	42575   Click image for larger version
ID:	42576   Click image for larger version
ID:	42578   Click image for larger version
Old 02-26-2009, 11:22 PM
Default The Notcher Indexer
Hi,
Here are some sleeves I made to slip over the pipe and you can index some holes if you need to.
Later,
Dave
ID:	42584   Click image for larger version
ID:	42585   Click image for larger version
Old 02-26-2009, 11:26 PM
Default Notcher in Progress
Hi,
Here is a couple of pictures of some steps in making the notcher.
Later,
Dave
ID:	42588   Click image for larger version
ID:	42589   Click image for larger version
ID:	42590   Click image for larger version
ID:	42591   Click image for larger version
Old 02-26-2009, 11:39 PM
67chevelle's Avatar
67chevelle 67chevelle is offline
Very nice Dave! I've wanted to add one to my available tools and now have one to copy.
A set of dimensioned drawings e-mailed to me would be appreciated
Mark
Old 02-26-2009, 11:42 PM
getatorch's Avatar
getatorch getatorch is offline
Tuned-Up Big Builder
Very interesting. Thanks for the pics.
"Freaking" is what you feel when things go wrong. The other word really refers to what happens when things go right... That one is only bad if it's against our will".
Old 02-26-2009, 11:44 PM
Charlie C's Avatar
Charlie C Charlie C is offline
More STEAM!!
Dave, that is very nice. I have had thoughts about making a notcher off and on but just have never did it. After seeing yours I am glad that I have not built one yet.
Old 02-26-2009, 11:56 PM
dubby's Avatar
dubby dubby is offline
Twice the size--half the man
I saw that in that thread and wondered where you got that. Now I know!
I have the one from HF. It does the job, but it's no where near that nice and always comes out just a tad off. Nice project for sure.
Wade's Custom Kydex
Old 02-27-2009, 12:03 AM
It would be a much nicer project if all the elements were in one thread so they won't get all scattered.
So I believe I will make it so.
Good looking deal, Dave.
Old 02-27-2009, 09:54 AM
Thanks Cutter,
I didn't think about that. I guess I should have made them replys instead of threads.
Later,
Dave
Old 02-27-2009, 02:32 PM
RancherBill's Avatar
RancherBill RancherBill is offline
there has to be an answer
Neat Project.
In the first post pic #2 there are two versions. Am I correct that the first one is 'fixed' height and the second one allows offset holes?
What kind of sleeve did you use for the drill shaft?
Warning Disclaimer What am I doing?
