-   Fabrication (https://www.shopfloortalk.com/forums/forumdisplay.php?f=13)
-   -   Slag Rack (https://www.shopfloortalk.com/forums/showthread.php?t=16268)
SlagKing 08-02-2008 07:47 PM
Slag Rack
1 Attachment(s)
Remember Big Blue?
He still works for a living. You can see the front rack I made so I can haul 20 ft. sticks.
those two sticks are 2x2 angle
SlagKing 08-02-2008 07:50 PM
1 Attachment(s)
For the newer guys, here is the shop.
Getting ready to cut the angle to size. 80 inches
SlagKing 08-02-2008 07:53 PM
1 Attachment(s)
Slag cutting the angle. Dewalt cutoff blade
SlagKing 08-02-2008 07:56 PM
1 Attachment(s)
Drilling the holes of the base.
1/2 inch hole
Drill press is a 1874 Prentice Bros. Camelback
SlagKing 08-02-2008 07:59 PM
1 Attachment(s)
Welding a couple pieces together.
Notice the Worlds Famous Lifting Welding Table
Rod is 3/32 7014 on a Hobart Stickmate AC
SlagKing 08-02-2008 08:02 PM
1 Attachment(s)
More stick work. All Welds are done on the inside. I didn't want any welds on the outside for this. I don't know why, just wanted to
SlagKing 08-02-2008 08:05 PM
1 Attachment(s)
Most of the frame together. Checking for square. It is.
SlagKing 08-02-2008 08:07 PM
1 Attachment(s)
Torch work on the panels. Notice the safety shorts, safety shoes. I do have on my Shade 5 cutting glasses though. Almost done
SlagKing 08-02-2008 08:25 PM
1 Attachment(s)
Done and I don't have to paint it. Customer will paint after install
This will go on a utility trailer for a zero turn mower to park under.
$200 for me.....lots of use for the customer.
Thanks for look'n
Slag the Seer
Jim-TX 08-02-2008 08:37 PM
Hey, looks good to me and I'm sure the customer will love it. I really like your safety shorts and sneakers too.:rolleyes:
Question. Do you not have a wire welder? I'm not being critical because I only got mine less than 2 years ago but I wish that I had gotten it a lot sooner. Projects like you just did are perfect for wire machines.:)
