-   Machining (https://www.shopfloortalk.com/forums/forumdisplay.php?f=21)
-   -   Heinrich Drill Press Vise Question (https://www.shopfloortalk.com/forums/showthread.php?t=47762)
CSakewitz 03-29-2017 11:31 AM
I recently acquired a vintage Heinrich Grip-Master drill press vise that has absolutely no markings indicating that it was manufactured by Heinrich. No P/Ns, Mnf., etc. cast into the base. I know it's a Heinrich 8-SV because the exact model can purchased new to this day. My question is this:
Did Heinrich supply these vises (unmarked) as part of the sale of vintage machine tools such as Cincinnati, Bridgeport, etc.? Basically, if you bought a Cincinnati mill, they threw in a OEM Vise.
If so, does that add value to someone that has some of that vintage tooling?
Clay
digger doug 03-29-2017 11:40 AM
Well, there have always been copies of that vice.
There are no name imports, some not too bad.
And FWIW you don't use that vice in a mill, it's for drilling only, usually light work
(not in a radial drill)
CSakewitz 03-29-2017 01:28 PM
I guess it might be a knock-off then instead of an OEM version. But you're right, the quality is really good.
Yeah I know it's for a drill press, I just used Cincinnati mill as an quick example.
rmack898 03-29-2017 08:03 PM
I have an old Heinrich and I have a very old Heinrich knock off. They look very much the same but they most certainly are not the same. If it's not marked Heinrich, it's not a Heinrich.
CSakewitz 03-29-2017 08:43 PM
This must be a knockoff since the only number cast into the base is the No. 8.
Thanks for the replys gentlemen.
Clay
