-   Mechanical & Electrical (https://www.shopfloortalk.com/forums/forumdisplay.php?f=36)
-   -   Jancy MagForce Mag Drill (https://www.shopfloortalk.com/forums/showthread.php?t=33576)
platypus20 05-07-2012 08:14 PM
3 Attachment(s)
Today, I picked up a new Jancy MagForce mag drill from the LWS.
1 - side view
2 - other side view
3 - coolant tank and guard screen.
Hobweld 05-08-2012 05:55 AM
That there is just purdy, all this new tool porn is killing me. :devil:
Ken
digger doug 05-08-2012 08:25 AM
Ooohhhh...shiny.
O.k......now what does the spindle look like ?
I mean to say (write ?) morse taper, straight shank (large b&d/Milwaukee)
or some other style ?
This thing got power feed ?
Maybe hook the I-pod up to the U.S.B. port on the side......
platypus20 05-09-2012 09:15 AM
Originally Posted by digger doug (Post 483191)
Ooohhhh...shiny.
It has the standard Jancy arbor that takes the 3/4" shank of the annular cutters, with 2 set screws set at 90 degrees from each other.
http://jancy.com/index.cfm?fuseactio...t&productid=55
IRONLORE 05-09-2012 09:48 AM
Always wanted one of those(mag-drill) but couldn't justify one for how little I'd use it. Sure is nice.
Glenn
Floptop 05-09-2012 10:09 AM
If he who has the most tools in the end wins, I think Jack will be crowned the victor. Good looking drill, and even better to be able to deal with your LWS.
digger doug 05-09-2012 11:10 AM
Ya mean I gotta mess with an allen wrench and TWO little (easily dropped)
set-screw's every time I take out the drill ?
UGH.
I have an old B&D monster with a straight shank, uses adapters to
#3 mt, you set up the 4 of them (jacobs chuck w/center drill,
then tap drill size, then c'sink, then tap) and quickly change them
out by removing the knurled ring. My contractor friend has a Milwaukee
that uses the same set-up.
I figured by now, these new fancy machines, would have a simpler
locking ring/ball detent arrangement to quickly change out the bit/tap.
And should not only have power feed, have a down stop to automatically
retract and shut off when done (peck feed would be nice too)
http://www.hougen.com/cutters/magdri...c.html#adapter
Looks similar to what I'm trying to do.
What do you make of those little Hougen right angle "lunchbox"
types ?
http://www.hougen.com/mag_drills/hmd...d115_main.html
I might just make up an adapter for my friends drill, using the common
quick change tap holder, adapting a jacobs chuck to one.
http://www.collistoolholder.com/cgi-...yp=CAT_4_TYP_C
They do allot of floor plates (1"-2" thick already grouted in place)
where they have to drill, and then tap many holes, all in place
using a mag drill.
milomilo 05-09-2012 11:26 AM
Mighty pretty. Looks much shinier than the old Miwaukie I used on the shop press.
kbs2244 05-09-2012 12:43 PM
Is there any way to re circulate the coolant?
platypus20 05-09-2012 01:23 PM
UGH.
types ?
using a mag drill.
They make all of that, but not in a sub $1000 mag drill. I personally have never had a problem with the set screw holding method. Besides all of the many cutters I have are set up for this. The 3 mag drills I own all use this method. I now have a mag drill set up with a regular chuck, and a small and a large capacity mag drills.
