Canaweld
Old 03-25-2006, 06:53 PM
sbi1's Avatar
sbi1 sbi1 is offline
Default Cutting UHMW Plastic
Has anybody had any experience with UHMW plastic? I have a piece 1/2" thick, 12" wide, and 10' long, that I need to cut down to 10" wide. My first thought is the table saw, and cut it like PVC trim boards, but I'm afraid that the more dense UHMW material will melt more than cut. This stuff was pretty expensive, which is why I ask-I don't want to ruin a board that was over $100. FYI, this will be for the bottom of a compartment on a fire truck, where a portable tank slides in and out of.
sbi1
Good judgement comes from experience.
Experience comes from bad judgement.
Old 03-25-2006, 07:02 PM
RED caddy's Avatar
Da Chief
I've had the best results with my variable speed Mikita sabre saw and a coarse, (6 tooth I think) wide set, wood crosscut blade. slowest speed and light feed pressure. Just go real slow, and let the teeth cut, rather than melt. RED
Old 03-25-2006, 07:06 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
same theroy...cut it before on a vertical bandsaw with a wood plade
maybe try it on a tablesaw with a "plywood" blade cut it to 11" first. that way you dont wreck it
Old 03-25-2006, 07:23 PM
Jeff's Avatar
Jeff Jeff is offline
Big Iron
skilsaw, tablesaw, etc. It cuts easy.
Old 03-25-2006, 07:33 PM
TJJ TJJ is offline
The plastics distributor we buy from at the shop uses a table saw to cut sheet to size for us. Lubricate with spray silicone. Don't dwell anywhere along the cut or it will melt.
Old 03-25-2006, 07:59 PM
Mongo's Avatar
Mongo Mongo is offline
Send a message via MSN to Mongo
I've used it a lot and a table saw with a coarse blade works great. As for a lubricant, one of the best is plain old water.
Don't ever step on the stuff when there is snow on it.
MM 251
Various other tools used to beat metal into submission
tekmongo@gmail.com
Old 03-25-2006, 08:01 PM
Mongo's Avatar
MM 251
tekmongo@gmail.com
Old 03-25-2006, 09:20 PM
Cebby's Avatar
Cebby Cebby is offline
Send a message via AIM to Cebby
I've cut 2 1/2" round solid on my wood miter saw with a fine 80 tooth blade. No problems with it heating up too much. It's nice to work with, but sure makes a mess (shavings)
Old 03-25-2006, 09:53 PM
Team DeSade's Avatar
Team DeSade Team DeSade is offline
Send a message via AIM to Team DeSade
One more vote for the tablesaw or just about any woodworking tool. I've used quite a bit of UHMW. Never had a problem with table saw, band saw, spade bits, rotozip, router, etc.
Terry
Old 03-26-2006, 08:37 AM
theonlybull theonlybull is offline
another vote for the table saw. a nice course carbide blade works fine for us. curves and other details are done with out wood bandsaw.
compartment for a porta-tank eh , might be easier then up high on the side like ours
