Canaweld
Old 06-26-2010, 10:24 PM
pawtech0's Avatar
pawtech0 pawtech0 is offline
Default mobility scooter build
I decided to build A mobility scooter for my Mom who has MS .It has taken me a couple of months to complete but it's finally finished. Here is how it came together.
pic#1 is start of frame and axle.
pic#2 frame riser with hole for seat pin.
pic#3 machined aluminum blocks with bearings inside.
pic#4 wheel with brass bushing attached to the axle to make up drive wheel
pic#5 boat seat from walmart.
ID:	62634   Click image for larger version
ID:	62635   Click image for larger version
ID:	62636   Click image for larger version
ID:	62637   Click image for larger version
_____________________________________ Phil
Old 06-26-2010, 10:32 PM
pawtech0's Avatar
more pics
Pic#1 frame with neck welded on and angles welded on seat riser .
pic#2 bearing blocks bolted on.
pic#3 neck with upper and lower bearings installed.
Pic#4 front fork with tire mounted.
pic#5 front fork and steering rod.
ID:	62639   Click image for larger version
ID:	62640   Click image for larger version
ID:	62641   Click image for larger version
ID:	62642   Click image for larger version
Old 06-26-2010, 10:43 PM
pawtech0's Avatar
More pics some fast forwarded to paint my Mom wanted it john deere colors I was going to paint it red.
Pic#1 rolling chassis with bushing installed for seat mount.
pic#2 with seat.
pic#3 floor support bars.
Pic#4 aluminum floor and rubber mat.
Pic#5 studs for front battery cover and aluminum plate for battery support.
ID:	62644   Click image for larger version
ID:	62645   Click image for larger version
ID:	62646   Click image for larger version
ID:	62647   Click image for larger version
Old 06-26-2010, 10:52 PM
pawtech0's Avatar
more pics
Pic#1 motor mount and first 24v geared motor but not the one I ended up with.
Pic#2 another angle of motor and mount.
Pic#3 front control pod bake and throttle levers.
Pic#4 front and rear covers made of aluminum.
Pic#5 brake disk and assembly off of a bicycle.
ID:	62649   Click image for larger version
ID:	62650   Click image for larger version
ID:	62651   Click image for larger version
ID:	62652   Click image for larger version
Old 06-26-2010, 10:59 PM
pawtech0's Avatar
more pics
Pic#1 seat bushing installed.
Pic#2 new motor 24v dc geardrive.
Pic#3 chain cogs and # 40 stainless chain.
Pic#4 cogs ang chain
Pic#5 gearbox on the motor.
ID:	62654   Click image for larger version
ID:	62655   Click image for larger version
ID:	62656   Click image for larger version
ID:	62657   Click image for larger version
Old 06-26-2010, 11:10 PM
pawtech0's Avatar
more pics
Pic#1 two lawn tractor batteries and wiring.
Pic#2 front steering stop and studs.
Pic#3 hand knobs to mount the covers they are from lawn mower handles.
Pic#4 charging port 3 pin xlr.
Pic#5 control pod 24v battery meter, light switch,key switch,forward and reverse switch and led indicators.
ID:	62659   Click image for larger version
ID:	62660   Click image for larger version
ID:	62661   Click image for larger version
ID:	62662   Click image for larger version
Old 06-26-2010, 11:19 PM
pawtech0's Avatar
more pics
Pic#1 floor mounted ,JD decals.
Pic#2 led tail lights.
Pic#3 led headlight built out of a plastic drain,an under cabinet led light and a pressure gage plastic lens and stainless ring.
Pic#4 headlight front of control pod .
Pics#5 finished scooter
ID:	62664   Click image for larger version
ID:	62665   Click image for larger version
ID:	62666   Click image for larger version
ID:	62667   Click image for larger version
Old 06-26-2010, 11:22 PM
pawtech0's Avatar
just a couple more pics.Last pic is of the charger.
ID:	62669   Click image for larger version
ID:	62670   Click image for larger version
ID:	62671   Click image for larger version
ID:	62672   Click image for larger version
Old 06-26-2010, 11:48 PM
pawtech0's Avatar
The speed of the scooter is controlled by a speed controller and a hall effects throttle the brake is also tied into the speed control so when brake level is pulled the motor power is cut .Forward and reverse is controlled by the switch on the control pod and two relays under the floor.Tires are solid rubber from tractor supply. Speed control ,throttle lever,brake lever and key switch are from electricscooterparts.com The motor and battery meter is from Ebay.I have about $300.00 in parts that I purchased most of the other stuff was just laying around.
Old 06-26-2010, 11:49 PM
akabull's Avatar
akabull akabull is offline
Maine-iac
Wow! that is awesome. I bet your mom is in deere heaven with that scooter. Nice build and excellent presentation.
Chris in Maine
