Old 02-17-2010, 12:01 PM
Don G Don G is offline
Default Bead roller plans
Hi Folks,
I want to build a bead roller and am looking for some basic plans and ideas on on building a machine and where to get rollers or how to make them. The whole process seems pretty simple, but I don't want to reinvent the wheel (no pun intended) if I don't have to. Pictures of a home built would be nice.
A 12 to 18" throat and 14 ga. capacity would be great.
Thanks,
Don
Old 02-17-2010, 12:23 PM
Don, look in the General Welding Information forum, Project & Equipment Index and see section #9 for some shop made rollers, brakes, etc.
Charlie C has a modification thread with his roller right now.
I want to go home!
Old 02-17-2010, 06:36 PM
Thanks Cutter.
Don
Old 02-17-2010, 07:59 PM
Charlie C's Avatar
More STEAM!!
This one was given to me. It is probably way too big for what you are looking for but maybe it will give you some ideas.
I should get the rollers done on Thursday as that is the first day that I was able to get to a bigger lathe so the axles could be machined.
Name:	Metal seamer 1.jpg
ID:	57269   Click image for larger version
Name:	Metal seamer 2.jpg
ID:	57270   Click image for larger version
Name:	Metal seamer 4.jpg
ID:	57271   Click image for larger version
Name:	Ridges made be metal seamer 2.jpg
Old 02-17-2010, 08:57 PM
Its not a set of plans, but is a kit, that requires a bit of fine tuning, but does work well after it finished. The Harbor Freight #34104 sheet metal bead roller/shear. Here is the thread link to the one I modified for an antique car headlight restorer.
http://www.shopfloortalk.com/forums/...ad.php?t=15551
Jack
http://www.harborfreight.com/cpi/cta...emnumber=34104
Old 02-18-2010, 10:52 AM
[QUOTEI want to build a bead roller and am looking for some basic plans and ideas on on building a machine and where to get rollers or how to make them.][/QUOTE]What Jack said......
Starting with the HF set, then searching the www( there were 4 or 5 last time I looked) for peeps that have beefed/altered/made better alterations to the stoor model.
I spent a weekend doing that the the HF set I bought and find that it has become a useful addition. It will now pert near double the work over stock. Plus having a chain reduction and drive motor makes it a keeper for sure.
I found it cheaper and much much quicker to have something I could use rather than making all of it from scratch.
