Old 10-29-2009, 02:21 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
Default Dayton Parts
I am working on a Dayton electric motor and need parts. Model is 6K321L. I have found the motor but haven't been able to locate a parts supplier.
Old 10-29-2009, 02:31 PM
partsgurut's Avatar
partsgurut partsgurut is offline
I have purchased dayton parts through grainger before but I don't know if they can get motor parts, but worth a call.
Tony
“Use it up, wear it out, make it do, or do without”
Old 10-29-2009, 02:35 PM
Pat's Avatar
Pat Pat is offline
Good luck Old Man. Our 3 year old Dayton Belt sander was down and out for 11 weeks because the on/off switch burned up, and it was a Grainger specific item. I can't believe Grainger does not keep any parts for this type of equipment on hand seeing that it is their own in-house brand. I believe all Dayton products are marketed by Grainger.
Old 10-29-2009, 03:38 PM
RancherBill's Avatar
there has to be an answer
You are right Pat, Dayton is owned by Grainger.
I found a guy that sells similar motors in the same series, depending on the part you need they might have it.
Electric Motor Warehouse
Old 10-29-2009, 03:49 PM
mtnkrake's Avatar
mtnkrake mtnkrake is offline
Default from graingers website
There are 12 parts listed below for:
Manufacturer/Brand: DAYTON
Model #: 6K321
Description: Capacitor Start Open Dripproof Motor
Additional Model Info:
Find Out More About This Product
Be sure you have the right model. Match the Additional Model Info (above) to your unit's nameplate/label.
View Printer Friendly Parts List Sort Table By:
Manufacturer Part # Description Ref. # Parts
Diagram(s)
10B001091000 Base
12A073370300 Fan Blade 7/8inbore
93D401483100 Shaft End Endshield
B453197940021 Bearing
C1032373004010L Start Capacitor L-3 3/8in Od-1 7/8in
C643035620001 Cover, Start Capacitor
C743074700000 Conduit Box Cover
P751056520211 Overload Protector
R352553670002 Resilient Ring
X745200540000 Opposite End Endshield
X832966460000 Stationary Switch
Z043144170000 Rotating Switch
Old 10-29-2009, 04:01 PM
OLD MAN's Avatar
Nobody was faster
Model #: 6K321
Diagram(s)
10B001091000 Base
Do you have a link or photo? are the bearings the same? I think the part I need may be one of the last two. It is a disc in a plastic holder that rubs against something turning. It has a wire on it. Jerry.
Old 10-29-2009, 04:24 PM
mtnkrake's Avatar
Default link
http://www.grainger.com/Grainger/rp_...0003860&save=1
Old 11-01-2009, 08:30 AM
chumly2071's Avatar
Urban Gunfighter
I'm a little late to the party, but most of the Dayton motors are made by Emmerson Electric. At least they were when I was using them for OEM applications.
Old 11-01-2009, 08:40 AM
OLD MAN's Avatar
Nobody was faster
It seems like all parts come from Grainger. It also seems Grainger does not stock all parts. If anyone had a Dayton motor in the junk pile I need a part. I think it will be the same on several motors. I haven't bought any available parts till I find this one. It is a plastic housing with several terminals on one side and a metal disc on the other. I don't know what it is called but it is stationery and applies the current to rotating parts. I don't have much left but I will take a photo and show it's location and hookup. Without it all I have is a pile.
Old 11-01-2009, 12:59 PM
mailtrain's Avatar
mailtrain mailtrain is offline
Tinman
Jerry;
How big of a motor is this?
