Go Back   Shop Floor Talk > Welding and Metalworking Forums > Shop Forum
Old 08-14-2009, 08:30 PM
endmill endmill is offline
Default Need ideas on cutting 2" Dow blue board
Hi Guys,
Need to cut 2" foam board to go in between the rafters,need ideas Thanks
Old 08-14-2009, 09:07 PM
RED caddy's Avatar
Da Chief
Two things, hot wire or electric carving knife. RED
Old 08-14-2009, 09:44 PM
Dr Dean's Avatar
Dr Dean Dr Dean is offline
Table saw super fast but somewhat messy.
Think outside of the box? Throw the damn thing away!
Sanity is highly overrated.
CaseIH service technician specializing in electrical systems.
Old 08-14-2009, 09:46 PM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
Crotchity and Snippy
I saw a guy line up a bundle of it and cut the whole thing with a chain saw.
Old 08-14-2009, 10:19 PM
randydupree's Avatar
randydupree randydupree is online now
Why, Hell Yes!
score it and pop it,just like drywall!
chainsaw? must have been a finish carpenter!
Old 08-15-2009, 11:00 AM
SlimJim's Avatar
SlimJim SlimJim is offline
Founder: Machining Forum
The first answer was the best. Hot wire. My brother ran a rope factory and they made them to cut rope, they work great on foam too. It is the best easiest and least messy way to do it.
Make your own, get a 12volt transformer, probably 1 amp would do it, get two insulated handles of some kind, run a piece of stainless steel wire in between each side and wire in an on off switch and that should do it. You could probably do it even better with a battery charger. Do a search and you will probably find a thousand plans to build on. Be careful.
Director of Purchasing
"Put a *face* on your SFT posts - contact MadamX for a unique or personalized Avatar. won't you?"
Tact is for people who aren’t witty enough to use sarcasm.
Old 08-15-2009, 11:16 AM
SlimJim's Avatar
http://www.youtube.com/watch?v=OaRs2...eature=related
Old 08-15-2009, 12:29 PM
Default Great You Tube
here is another one
http://www.youtube.com/watch?v=KEKcL...eature=related
Old 08-15-2009, 01:16 PM
kbs2244 kbs2244 is offline
Randy has the idea.
Most guys just ues a razor knife with the blade extended out to max.
I have use an old kitchen knife with a longer blade.
But you are not talking a high precision job here.
It will snap just fine down a score.
Old 08-15-2009, 02:17 PM
Mild Steel's Avatar
Mild Steel Mild Steel is offline
The long serrated kitchen knives work well for foam but it sure would be fun to make a hot wire cutter
You are not grown up until you run out of birthdays!
clyde@m2texas.net
george@shopfloortalk.com
bob@shopfloortalk.com
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
