Old 02-14-2009, 12:46 AM
widetrackman widetrackman is offline
Default Old Craftsman horz bandsaw blade guide
Well I think Cutter is rubbing off on me. A while back I was at a country Blacksmiths for something ? anyway he was griping about a old Craftsman 4x6 horz. saw on a nice angle iron frame he was using. It would not cut any where near square. I asked did he want to sell it. He quickly replied, 'give me $25 and get it out of my sight'. I complied with his request and left. I just had to have the little guy Upon later investigation it appeared a snap ring had come off one of the blade guide roller shafts, letting the roller fall off. I dont know where to get parts other than Sears and I think they want $28+ shpg ea. Well being the Atlas lathe is running thought this might be something I could machine. It measures .975 od. x .430 tk w/ a .240 bore solid material. I dont know if I need a special material. I was thinking about turning a piece of 1" cr bar, drill the bore, part off a !/2" piece and face both sides. What do you Guys think. BTW did Atlas build this Saw? The tag says 101.22022.
Old 02-14-2009, 01:03 AM
Widetrack, are you sure of that model #? I just entered it into the Sears database and got nothing.
Can you post pictures of it?
or is it like the one in this picture?
I want to go home!
Old 02-14-2009, 01:08 AM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
I used to have one of those, it was my first bandsay. It replaced a sears back and forth job. The only trouble I ever has was the control valve for the hydraulic cylinder required constant attention.
Old 02-14-2009, 01:27 AM
Cutter, that looks like the same saw and I am perty sure thats the number on the machine, its the original craftsman tag. I'll check it again.
Old 02-14-2009, 01:28 AM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
The 101 signifies an Atlas built item.
Ory-gun Boy!
Old 02-14-2009, 01:32 AM
Old Man you are right about the cylinder. Haven't figured what to do too make it work better. First the roller guide repair.
Old 02-14-2009, 01:34 AM
Paychk, does Clausing or someone other than Sears have parts?
Old 02-14-2009, 01:40 AM
The one in the picture is a Sears 108.22920 according to the data plate.
Off the top of my head, I don't remember who manufactured it or if I even knew.
108 is not listed in the index I found on OWWM.
I want to go home!
Old 02-14-2009, 02:08 AM
I found some other pictures that should help decide whether we're talking about the same saws.
1. 2 & 3. Do your blade guides look like these?
4. And here is the cylinder.
The reason I'm interested in whether the guides are the same is these are small ball bearings. If that's what your's had then I would take one of the others to a local bearing store to see what they say.
ID:	41846   Click image for larger version
ID:	41847   Click image for larger version
ID:	41848   Click image for larger version
I want to go home!
Old 02-14-2009, 02:17 AM
RancherBill's Avatar
there has to be an answer
108 Covel Mfg. Co.
From Craftsman Vendor List.
Tags
craftsman bandsaw, horizontal band saw
