Canaweld
Old 02-08-2007, 07:53 PM
Default Square holder
When setting up larger projects sometimes you need three hands when tacking plates together and other setup work. This little tool holds the square for you and comes in handy for setting a mag level. I used 3/4" X 3" flat bar cut 2 1/8" long [the 1/8" is for facing on the lathe if you have one] and cut two pieces of 5/32" welding rod 1 3/4" long. Using the welding rod as spacers I tacked one 2 1/8" up from the bottom and the second one about a eighth down from the top centered cross way on the plate. Then clamped the second one on top and welded it out. With some grinding and a little sanding make it stand up square it is ready to use. There is no need for a lathe other than to make it look a little better.
Name:	set up 1.JPG
ID:	20062   Click image for larger version
ID:	20063   Click image for larger version
ID:	20064   Click image for larger version
ID:	20065   Click image for larger version
Name:	mag level 5.JPG
Old 02-08-2007, 07:59 PM
Wrenchbender's Avatar
Wrenchbender Wrenchbender is offline
Mender of the Yellow Iron
Location: Belton South Carolina Home of the Standpipe Festival
Slick it beats the way I've been clamping my square to a peice of 3"X3" angle.Of coarse I would just loose the holder if I had one
"Banking establishments are more dangerous than standing armies. Thomas Jefferson
Old 02-08-2007, 08:38 PM
67chevelle's Avatar
67chevelle 67chevelle is offline
very, very cool.. I gotta make one of those..
thanks for the post
Mark
Old 02-08-2007, 08:43 PM
84ZMike's Avatar
84ZMike 84ZMike is offline
Great idea....I'll have to make one (an ugly one as I don't have a lathe)
Mike
Old 02-08-2007, 10:08 PM
Pilgrim Pilgrim is offline
This must be my lucky night! Two great ideas in one sitting - the square holder and the ring roller! My two favorites since the welders finger. And best of all they're simple and cheap enough that even an idiot like me should be able to put these together quickly. And Mike... I'll be with you in the "ugly" no-lathe club! Thanks for the great ideas guys!
Pilgrim
You say there are no absolutes. I say... are you sure??
"If you need a tool and don't buy it, you pay for it without receiving any benefit." Henry Ford
Old 02-09-2007, 11:38 AM
If you don't have the material or the means to get it really square, start with a cheap set of 1-2-3 blocks.
http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INLMK3
Old 02-09-2007, 12:34 PM
astroracer astroracer is offline
The 1-2-3 blocks work well. I used a little 90* angle block. Drilled three holes in the square and simply lined it up with the edges of the block. Works slick and it is heavy enough it doesn't get knocked over very often. I have a number of bolts in my "set-up" drawer that I have turned to a point. Makes for easy reading when setting suspension and bracket heights.
I know... I only have an Easybake right now but I am saving up for a "Real-Meal"...
Suzy
Old 02-09-2007, 01:15 PM
Charlie C's Avatar
More STEAM!!
Gee I now have a use for the 1-2-3 blocks that I have. Thanks for the suggestion.
Old 02-09-2007, 06:30 PM
I added a bolt to tighten against the square.
ID:	20090   Click image for larger version
Name:	on square 7.JPG
Old 02-09-2007, 06:59 PM
I saw a deal at MSC or maybe ENCO on some 1-2-3 blocks awhile ago, so I ordered a pair. They sent me a box. It was supposed to be a box of two, but they sent a case of 20 pairs, in one box. Oops! I figured the weight and hassle of sending things back wouldn't really benefit anyone, given the low cost. Now I just have to figure out a use for all these blocks.
