Oh Shade .........by Franz........More on Oil's How hot can you run hydraulic oil? ......started by Cavalry Compressor oil.........Question by rusted Shade...Fluid question ....Started by pat.....hydraulic fluid or power steering. Oil Question for Shade....By DDA52....Would you run a synthetic 15w-40 in a welder. Headstock lube ..............by moe1942 Standard No. 149 oil.........by jhill...portable bandsaw gear oil Angle Grinder Gear Lube?......By coleasterling Oil Change Basics .........by Shade Tree Welder Fluid Flush Fallacy ...........by Shade Tree Welder Shade, I need oil on troubled waters..........started by EngCan synthetic oil? ...........started by wolfgangwelding =========================== Coolant Recommendations...........Started by deere2210 coolant.................Started by digr Keeping coolant from freezing........by Rio Grande Refractometers .......Started by X-ray Lubricant for honing..............Asked by Rolal fe Need machine tool oil advice ......by Walker Mobil 1 for way oil? ......by Hobweld =========================== Two stroke engine gas to oil ratios charts. ...by Harvuskong Two stroke question? .....by wayne64 ===== what kind of paint to restore my lathe with ...by Jackel440 Loctite shelf life ......by clive Warning GE Silicone II Caulk not curing!!!!! ......by H80N Best thread sealant .......by Jim-TX glue..........Started by Dallas B Patina formulas for brass, bronze and copper posted by LW Hiway The Magic Oil comparison chart, from this thread, Penetrating oil. Homemade Penetrating Oil ....by slim Look here Midmo: Powder coat Removal Product .........by SlimJim Removing Chrome Plating ..........by Tony T. Purple Power..........By OldRedFord..........Cleaner/degreaser. Evapo Rust ...by tnmike <> Electrolytic Rust Removal Using current to remove rust. ........by LW Hiway Derusting with Oxalic acid? .....by USMCPOP Skunk Cure ...by mailtrain Yellow Jackets ...by engineman56 .....killing and cure? Last edited by Index Manager; 05-16-2013 at 02:26 AM. |
Bandsaw modifications .....by Ironman
Bandsaw modifications........By Wyoming Coiling a bandsaw blade - 3 links Bandsaw coolant oil discussion started by digr Bandsaw Adjustment Discussion started by Dirtdigger Band Saw Mod/Clamp started by Broccoli1 Wells horizontal bandsaw Discussion Started by trukfan Last edited by Index Manager; 08-07-2012 at 04:05 AM. |
Free down load, Calculator (version 212 is free) for
Right Triangles, Oblique Triangles, Bolt Circles, Sine Bars....found by GWIZ <> Baum Calculators sprocket ratio, hydraulics, v-belt length, reservoir capacity, etc. <> Unit conversions. <>Metric Conversion Calculator, and 2 downloads <> More online conversions <> A good link for your favorites <> Handy Dandy Charts Hale Pump Data For Practical Use.........posted by mccutter...fluid-type conversion info. pdf chart Has anyone ever used this software to layout angles for ...Q, by Steve V.......Pipe Joint Template Software Formulas ......by digr .....pulley speeds Useful shop calculators ....by Paychk Calculating Weights & Center Of Gravity...pdf found by LW Hiway Tank Volume Calculator thread by Charlie C, link by OleDog in #2 Tapeculator and other Math Tricks by digr & Diverbill45 Odd Sized Patch by irnsrgn Last edited by Index Manager; 12-29-2011 at 04:23 AM. |
This Link will give you a view of all the SFT threads listed by titles........by GWIZ
<> Bolt strength reference chart .....by chumly2071 <> Bolt Torque Calculator. <> Trailer parts & information Link to small parts Miniature fabrication parts needed ........by Boogity Railroad Rails .....by mudbug ....Spec. Link Bolt science ......found by USMCPOP Steel Profiles with dimensions.... .......by Ironman Layout and Fabrication of Steel and Pipe...Pdf........found by LW Hiway I-Beam load..........Started by Harleyrider Links to Metal Weight Calculators by several e-books Henley's Formulas .... found by H80N e-Book... Machinery's Handbook 11th. edition 1941 ......H80N Pdf book Interesting Blacksmithing Book .....found by Whitetrash Download Sites for Machining & Electrical E-Books by GWIZ & others Pdf's A list of how to,s ......found by slopdog .........myriad of machining pdf books and more. Sears and Craftsman Source Product Code (Who Made this Sears Tool?) Contributed by RancherBill in This Thread. World wide patent search ....found by Paychk Link Outdoor Power Equipment Information ...found by Lw Hiway Link to pdf Metal Repair Procedures .....found by LW Hiway Aviation Maintenance Handbook .....found by aerometalworker Navy Training manuals...found by USMCPOP Navy Training manuals...found by tnmike <>Manuals Manual Site....by RancherBill......auto repair, small engine, generator, motorcycle....etc. W.E.Williams .........found by Camdigger. Follow the links to Old South Bend Manual Trove. Be sure too also click on the logo for other machine manuals, not just South Bend: DoAll, Cincinnati, LeBlond, Rockwell, Sheldon, Standard-Modern, Misc. ======================== Some Off Site Links. This is a category limited to various sites with projects not posted on ShopFloorTalk. Vintage Projects contributed by TommyA Popular Mechanics Magazine on Google Books, link supplied by atwaterkent Popular Science on Google Books, link supplied by RancherBill Vintage Farm Plans Printable Paper Hundreds of forms you can print, link supplied by CEC. Links allen bradley plc .....started by Scotts...PLC links Link Gun Manuals ...found by Tim KS Last edited by Index Manager; 05-17-2012 at 02:12 AM. |
<> Gantry Crane Information
101 Designs, the tripod build. ........by Lu47Dan Links to Rigging..pdf..... found by Cavalry......TM5725 Army Manuals and TM-5-125 Calculating Weights & Center Of Gravity...pdf........found by LW Hiway Steel cable terminations .............by tnmike.........also help full links on cabling by others. Jib Crane Complete .........by DDA52 Small Jib Cranes by SNAFU ========== Shop crane .....by used-iron Harborfreight Jib Crane .....by GAS .... Adding thrust bearing, modification A hoist fine feed attachment ......by digger doug 101 Designs, the tripod build. .....by Lu47Dan Hiways Jib Crane. The Picking Up and The Putting Down...By LW Hiway Small Gantry Type Crane ........started by jamesemery728.........Discussion Last edited by Index Manager; 05-17-2012 at 01:51 AM. |
Homemade fire starters ....by tnmike
How to cut a hole in glass? .......by panhandle redneck redneck flap/sanding sleeve ...by Cutter .....wood dowel for polishing holes. SIMPLE solutions to pesky problems by Mikey (and others) non-reversing clutch........Started by Charlie C Masking Tape by digr Grinding Aluminum/Cleaning Carbide Burrs by Calvary & others Bushing Removal by digr Removing broken bolts & studs by Jeff ===== Moved from Index Problem solving, tips, tricks and fixes. Removing broken bolts & studs by Jeff What is Passivating? and Cleaning Metal with Electrolysis. How to cut a hole in glass? .......by panhandle redneck Radius Markers by Digr, irnsrgn Framing square uses for metal by irnsrgn Some Toys by irnsrgn M Toy by irnsrgn I'm a Cheap Skate by irnsrgn Storage Solutions by IForgeIron Grandpa's Bender by irnsrgn The Orange Peel by david r Last edited by Index Manager; 12-24-2012 at 12:38 AM. |
New category added to Tricks and Tips.
Surface prep and finishing. Link > Info on surface finishes and Corrosions. ....found by LW Hiway redneck flap/sanding sleeve ...by Cutter .....wood dowel for polishing holes. Rust removal with molasses.By popular demand .....by matthew_g engine turning? .......by Ram48 ...swirl surface finishing. Rattle Can Ball Rattler or Lazy Boy mixer .....by LW Hiway |
| Thread Tools | |
| Display Modes | |
